Hi,
I just noticed this after i upgrade my receiver to Onkyo 605.
I have been using the 5 sockets power brick from Soundtec with power surge and fuse inbuilt. The following are connected to it.
Receiver, BP player, DVD player, Mio + modem + Sub.
I usually only try to switch on max 3 devices such as Receiver, BR and Sub.
I recently noticed that the sub pop whenever I power it up.
Has this to the cheap power brick? Do you think upgrading to a Xindar kind of power brick helps? If so, in what way.
Thanks
