my friend has a Marantz CD 17 Mk 3, the display is off ...i understand that there is a 4 step procedure whereby you can  on back the display again..he has lost the manual..anybody can tell me how to activate the display ?
Thanks !
I used to own this cdp, but I don't recall the display being able to completely turn off, rather clicking on the dimmer/display button on the remote 3 or 4 times can cycle through the dimness of the display from very bright to dull....it's been quite a while but I could be wrong...
Hope someone has the solution for you..good luck.
Problem solved ...I brought my CD 63 remote over n activate thru the dimmer button...some how his CD 17 MK 3 remote is different
Thanks !
