Speaker have tick sound
I am using Usher S-520 and a modded T-Amp .. I had been observing for the past 3 days that almost every song that i am playing have a tick sound .. Is it the Amp or the speaker problem ? Should i stop playing now ?
Thanks
how about the source? did you try playing using different disc/player? it could also be interference from cable that is not ground properly...
  • Author
Ok.. thanks for your help..
It is the sound setting in my com .. nothing is wrong
