bolts1624705732 Posted August 30, 2007 Posted August 30, 2007 Was at COMEX today. On level 6, there are 2 booths. One carry APC power distributors, less than $40 per pc. Another carries the Shure line of earphones. The top of line SE530 is available for sale and demo. Very nice...natural mids, but a bit bright on the top end and surprisingly deep on the bass (19Hz to I think 20MHz). The impedance is only 36Ohms, so, any normal MP3 player can drive them. Unlike those handphones. There's also Sonic Gear, selling tube 2.1 systems...I'm not sure if the tubes are just gimmicks or they are really used in the pre-amp stage. There's one model that has got a pair of monitor-sized speakers that are really heavy, comes with binding posts. Unusual for PC speakers. Quite good sound. Go have a look see, look see.......... ;D
Heng Posted August 30, 2007 Posted August 30, 2007 Was at COMEX today. On level 6, there are 2 booths. One carry APC power distributors, less than $40 per pc. Another carries the Shure line of earphones. The top of line SE530 is available for sale and demo. Very nice...natural mids, but a bit bright on the top end and surprisingly deep on the bass (19Hz to I think 20MHz). The impedance is only 36Ohms, so, any normal MP3 player can drive them. Unlike those handphones. Wah, at S$815 the Shure SE530 earphone better be good... :o
2100 Posted August 30, 2007 Posted August 30, 2007 Wah, at S$815 the Shure SE530 earphone better be good... :o Well, it's a few ten dollars cheaper than my Fostex 206es-r.
bolts1624705732 Posted August 31, 2007 Author Posted August 31, 2007 Wah, at S$815 the Shure SE530 earphone better be good... :o They are running promo there. S$739, they told me.
FookLai Posted August 31, 2007 Posted August 31, 2007 Btw, what is the good use of APC power distributor for HT or stereo? I will be getting Xindak XF1000 soon, are there the same? Fook Lai
mojoe1624705824 Posted August 31, 2007 Posted August 31, 2007 Actually for Shure, you guys should check out Amazon... I got the last generation E4G at half the price compared to SG's pricing. With USD at it's low, it's worth it.
bolts1624705732 Posted August 31, 2007 Author Posted August 31, 2007 Btw, what is the good use of APC power distributor for HT or stereo? I will be getting Xindak XF1000 soon, are there the same? Fook Lai I think I saw this one there. But, this model should cost more than $40. http://www.apc.com/products/family/index.cfm?id=220 For HT, it's fine. Anyway, XF1000 should be better.
Guest Assys1606 Posted August 31, 2007 Posted August 31, 2007 I think I saw this one there. But, this model should cost more than $40. http://www.apc.com/products/family/index.cfm?id=220 For HT, it's fine. Anyway, XF1000 should be better. Check out this - Belkin pureAV home theater surge protector at USD19.99.
