What DVD player WILL match DEnon-AVC A11sr
Guest chi1982
Guest chi1982
;D
HI DENON AVC AVR OWNER S
i am now using the DENON AVC A11SR WITH PIONNER 575 DVD
THE SOUND IS QUITE HARSH  ???
I THINK IT MAY BE THE PLAYER
wHAT dvd PLAYER YOU THINK IT WILL SOUND GOOD WITH DENON AVR ??
how is it connected to the Denon?
actually - with receivers, it is very unlikely that you are listening to the player at all; they are just transports for the most part
if you connect it using stereo analog, the receiver does A/D conversion to do bass management etc, then does D/A conversion again to amplify. i.e youa re listening to the receiver DACs
if you connect it using digital (coax or optical) you are listening to the receiver DACs too.
so - harsh... what speakers are you using?
