eow2 Posted August 12, 2007 Posted August 12, 2007 Dear Folk, anyone know to install the pa ceiling speaker? out of touch fwith hifi for a long time. heck even forgot my original password. :'( i had the ceiling speaker as below on it back i found the following..seem it some sort of a transformer. do i need any special gear to fix/link it up my my amp?
Spunky Posted August 12, 2007 Posted August 12, 2007 Dear Folk, anyone know to install the pa ceiling speaker? out of touch fwith hifi for a long time. heck even forgot my original password. :'( i had the ceiling speaker as below on it back i found the following..seem it some sort of a transformer. do i need any special gear to fix/link it up my my amp? They require PA amplifier which I believe has a higher voltage output.
Spunky Posted August 13, 2007 Posted August 13, 2007 Oops! Forgot....if using normal amp, I believe can bypass the transformer. Does the driver have any crossover components?
eow2 Posted August 13, 2007 Author Posted August 13, 2007 There no cross over I had try connecting it direct to my audiolab intergrate 8000a. it work however it was seriously underpower and sound very soft and nope i didn't see any crossover at the back. it was just the driver itself with the + and - ve cable feeding thru the miniture transformer seen abv.
Spunky Posted August 13, 2007 Posted August 13, 2007 yup, the transformer kinda stepdown the higher signal (V) transmission which the PA systems use because of the long length of cabling thru the building. since u r using non-PA amp, can bypass it
zermat Posted August 15, 2007 Posted August 15, 2007 P A speakers work off a 70V or 100V line from a PA amplifier. You should see either a 70V or 100V label on one side of the transformer. On the other side, there should be a 4 or 8 ohms marking with two wires soldered to the speaker. If it is marked 4 ohms, then the speaker is a 4 ohms speaker... Disconnect the wires connecting the transformer to the speaker terminals and connect the speaker terminals directly to your home amplifier. PA ceiling speakers are normally rated at 3, 6 or 10 watts, but they are usually higher efficiency (SPL) speakers.
