Hi friends
Been using a HD STB from MC for HD Ch 5, as I live in a valley, reception isn't ideal, anyone knows where to buy a better antenna than the one MC provides?
Thanks
P
Hi friends
Thanks
P
Try positioning ya antenna closer 2 e windows. Nothing much you can do unless you can tape onto a roof-top antenna which, no thanks to StarHub, is no longer in use.
Phil
Thanks Phil
You don't want to see the obscene positions I get to in order to improve recepttion. A yoga instructor cum climbing instructor will be mighty impressed.... :)
I had a new line installed to my hi fi room but the tiny antenna c722 passed me worked better than that :(
Need a better thing but not sure if a new roof-top array is the way to go. Being in a valley and far from Bukit Batok doesn't help.
But I saw a discernable improvement with HD 5 over regular Ch 5
Phil
Hi! Pete
There is a shop in SLT deals with signal reception equipment. Many years ago I purchased one antenna booster from them. It is the 1st shop on the right on the 1st floor when entering from the main entrance. Sorry, can't remember the shop name.
Hi! Pete
ya quite obvious, i think they stock the DX antennas, saw that brand plastered all over the shop front.
Visit Draco website (www.skycomsatellite.com) .There is Antenna input FAQ or how to make full use of your present roof top Antenna.
Thanks bro
Just went, website is down?
Visit Draco website (www.skycomsatelite.com) .There is Antenna input FAQ or how to make full use of your present roof top Antenna.
Trust me, Bukit Batok has many blind spots. I can't use building antenna to receive aerial TV channel properly.
After dinner yesterday and this morning, I went to some shops in the North - will go SLS in the week
The most common word is HUH?
a, noone knows much about HD TV STB, and these are sales staff in electronic shops
b, they know even less about the antenna and what is needed to get good signals
c, they do not sell them seperately nor do most of them know the antenna section
d, either that or I was speaking Greek to them all the time
Sigh....
Pete, if you head to Causeway Point, there is this shop on the 4th floor called Stereo xxx that carries the SoundTech brand of antennaes which is labelled suitable for both Analog and DVB-T use.  Can give it a try and check it out there.  I think some folks have previously posted about this brand in the Mediacorp HD Trial thread.
Soundtech? Great I will go to their distributors - friends :)
Thanks
BTW I bought my Dynaudio Centre from that shop a long time ago
Seems the Soundtech doesn't do HD antennas now, asked my friend's shop and Stereo, so I called Draco and I will be buying their Ant 100 model tomorrow $45  :'(
Technically there's no such thing as a HD antennae.  All you require is one that is able to receive UHF signals with a certain gain level.  Hence, those SoundTech models which can accept UHF should be able to get the signal.
