Hi like to get a show of who would be interested in gettin the below
acoustic products in a MO. All prices r bfore MO discounted prices.
1)Ecophon Master A tile 600mm x 600mm (box of 20) $$400
   Ecophon Master A tile 1200mm x 600mm (box of 20) $800
   Ecophon Focus A tile 600mm x 600mm (box fo 28) $308
   Ecophon Focus A tile 1200mm x 600mm (box of 28) $616
*Take note master series tiles onli have models A and E in stock n for focus seris models A,D and E.
Also if u find 20 or 28 pieces r much more than u need u can get 1 or 2 people to share the box with you.
2)Auralex Gramma pads $135 w/o gst
   buy 10 or more get 5% discount, those interested in other auralex products i can check out pricing for you.
3)Onix Diffusor (2ft x 2ft) $200 per pair
  • Replies 26
  • Created
  • Last Reply
Top Posters In This Topic
Hi Koma,
Is there any pics of these acoustic products?
Meow
When u came to my house, sure u saw the echophon on my backwall and beside the subwoofer right? :)
Hi Koma,
Meow , echophon is a square piece(different size) of absorbing materials . It is light but cannot use double side tape to stick . You need to make a frame to hold and hang it or use tiger glue to stick . I do not own any but saw it at bro muscular27 and oliverlim house before .
How about those you used, bro? I only know Diffusor and the aBsorber which you told me. Are those that you are using now? Hee hee... Ku ku starts to learn now... Hee hee ;)
As for Bro Fabryuk, yes I saw those materials, especially those beside your speakers & sub. Forgive me, I thought those are normal foam.  :P
yup mainly used to "float" speakers but subs also can. dun worry even
the mopads is enough to support an ultra ;)
i might be interested in the gramma pad. this is the one for subwoofer base right?
Hey Koma,
What would be good for floating a PB10? I might be interested if the mentioned Mopad is a cheaper alternative.
Also, I need to soundproof my door (sound from going out and coming in), I'm experiencing a lot of "outside" noise when I'm watching a movie sometimes, and it can get rather distracting. Please advise.
Cheers!
May be interested in this.. is it the wooden type or styrafom one? googling didnt yield any pics.. When u intend to close the order?
tone deaf, the GRAMMA fits the PB10 perfectly. Mopads r cheaper though...
the auralex mopads would be more than adequate. hmm like that maybe u
would like to try door seals on ur door 1st.
Hey Koma,
Cheers!
bro if im not wrong is the styrafoam type. u can ask bro joamonte 2nite
cause i saw him using these. yah tried searchin for a pic on the net
but cant seem to find
Hey Kzone, thanks for the advice! But are the Mopads and the Gramma made from the same material?
Ok Koma, shall heed your advice on the door seal. Do update us on the Mopads if available for order.
Cheers!
Yup, that is part of it .
It is same materials . Diff is Gramma with a nice wooden platform . So for those having box subs, just use the Mopad, cheap and good.
can mopad fit a cylinder sub? :P at least if it doesn't sound that gd, i can always use it on my other speakers. hehe
Can fit but not stable to me so ans is better dont(Try it at your own risk) . Cylinder need to pay more for Gramma platform  ;D Or you can cut a thick Mdf board, place the Mopad below then can . Box sub is mostly ok . SvS box or subs that has a wooden platform below is the best . Btw, 1 Gramma not big enuff for PB12+/2 sub . can hold but not that stable to me . It will need 2 so Mopad stiill the best option(cheaper too) and serve the same purpose . Just place each at a corner .
In addition , I have placed myself on top of my ultra/2 sub with Mopad below, it still can tahang without any sign of flattening, good.
High density Foams is good for SvS sub lift up . Not day and night difference but there is still can-easy spot difference(reduce floor noise and make it more airy)  ::) On the other hand,using spike cones on SvS box sub is not a good idea . You get your floor into trouble or yourself if need to shift (I tried it before :'()and seems no difference to me . Mopad or Gramma , yes . Maybe the spike cones not high enough for SvS sub , I guess so  ??? coz my MK sub got diff using the original spikes but it is higher .
Sounds great Jason! I'm in for the Mopads then...
Koma, will this MO be kicking off?
Otherwise, who/where can I order from individually?
You can buy yourself from Telex communication . Look for Alice . It is situated at Ubi . COD only , btw. And call before you go in case they no stock .
Address: 3015A Ubi Road #05-10. Kampong Ubi Ind Est . Tel: 67468760.
Full name for the Mopad is Auralex Mopad . Per set comes with 2pairs(4pcs) . For speakers use, it can tilt angle(up or down) too . When you see it , you know how to tilt liao .
Guys, a word of caution for those who like me, know nuts abt acoustic treatment & using SVS lowest end sub... instead of getting more bass after using the platform, u'll find the sub to be underpowered instead... My blood immediately rushed to ny head.. luckily bro Jason here says its normal to feel dat way.. haha...
Then bro Jag helped me to make the sub a little fiercer, after awhile still not enuff.. now always waiting in the B&S for the only thing that can increase the bass ouput.. sigh...
Hehehe , since bro kzone mentioned this , I got something to make clear . The higher you lift up a sub , the more db lost but cleaner and airy . The more bass traps you put , the cleaner and punchier the bass,  but you will want more bass liao . Likewise for acoustic treatments. When you absorb the first reflection on all speakers, the more precise the details and image but you also lost few dbs . Need to crank up the volumn to compensate back . However , this is the more true sound from your speakers so don worry . Everything is normal . Those who have visited me know the results and the advantage of acoustic treatments .
yah i be gettin the mopads also. i need a list of the stuff that u guys want
so that i can get the quantity i need at least to warrant a discount from the
supplier. Maybe tonedeaf u can start off with the list 1st ;)
Jason if im not wrong alice office now in Bishan liao frm what i
spoke with her ydae .
Oops , sorry . Outdated liao . Have not bot anything from them for almost a year  ;D
