Hi All,
Sorry to post again.
Though I have not audit the speakers. Which of the following do you guys think is the most approiate for vocal and light jazz ?
JM Lab Cobalt 806 or Chorus 806V -- $1200
Spendor S3 -- $900
Used Monitor Audio Studio 10 -- $950
Would appreciate yr inputs. Thx.
Hey Bro
You should also audition the Pioneer S-A4SPT-PM "Pure Malt" speakers
They are available at Merdeka (Sim Lim Square)
The listed price is 1100$
I have auditioned them and they sounded very sweet. Especially with vocals.
Shop was using Robertson pre/power amp to drive them.
what amplifier are u going to drive with?
suggest to take the amp to audition.
For spendor, should also try the S3/5e. Not easy to driven but if match well with amp, it'll sound very good.
