Hi, I've got the pio dvd player for awhile before i got a sharp PX 37" LCD. So i got a HDMI cable thinking that i could use the upscaling feature but i could not.
Two problems that i observed:
1. HDMI indicator does not turn on even thought connected to the LCD TV.
2. The Initial setup items for HDMI resolutions could not be selected. it stays at 480p/i no matter wat software i put in it.
Any bros with similar problems ? Thanks
Can the player do scaling at all? IIRC i tried to upscale my friends set but was not able to do so.
To me it looks like a normal 480p player but i could be wrong  ???
According to their website, it's supposed to able to up-convert. I remember reading somewhere that it uses Mediatek chipset for that.
# HDMI interface (DV-696AV-S, DV-490V-S)
HDMI (High Definition Multimedia Interface) is an industry-supported all-digital audio/video interface. Pioneer's new DVD players with HDMI outputs and video up-conversion allow viewers to watch and listen to DVDs with exceptional audio and video resolution. It also makes set-up and connection to the rest of A/V components much easier since everything can be connected through a single cable.
Were u playing any dvd while trying to select HDMI options? If yes, you have stop play to be able to select some of the options in the menu. Hope it helps.  :)
The setup menu for HDMI output resolution could only be made when the machine is at stop. So i did stop the playing and tried, however the menu seems to be there but was faded out and not changeable.
I suspect the player did not detect a HDMI connection since the HDMI indicator light did not light up , however a 480p or i signal was transmitted via HDMI.
hmm thats what i encounter also  on my friends set. Let me know if its successful so i can get my friend to try it.
Problem solved! Turns out to be a bad cable. So went to get a new Daiyo cable. The guys at pIONEER are very helpfull and test my set on-the-spot.
However the hdmi sync is a little edgy, the sequence is important. Need to turn on DVP first, then display. if not the sync may not happen some times.
  • 4 months later...
Hi there..check with u guys, is this player region free? cuz i just bought this player and it don play region 1 disc at all. Check with saleperson before buying and he say they have already ask their supplier to make it region free..seems like i have to make another trip down to Harvey again to exchange.. :( 2nd trip already..1st trip to exchange becuz the door won't open..
