Hi guys, i m looking for a 7m subwoofer cable, is there any place for custom made 1? roughly how much? thanks!
As what cmk has recommended, LHS at SLT 2nd floor sells Belden 1694a cable at $3 a meter & the Canare Crimp RCA plugs at $7 each.
For your 7m cable, it will be ($3 x 7m = $21) + ($7 x 2plugs=$14) = $35  ;)
only $35 for 7m? sounds gd to me, will go check it out :)
btw is there a better cable then belden 1694a? maybe around $5 per meter?
1694a are used for professional installation so i think the quality should be good enough :p I am sure Robert will be happy if u wanna pay $5 per meter :p (joking)
But seriously, if you do a search in the forums the 1694 is usually more than sufficient. It is used by a number of bros here.
Canare L-5CB is also an alternative (this is the one i am using)
Canare L-5Charlie Bravo is also an alternative (this is the one i am using)
than how much is ur canare then? :)
Cant remember but not too far off from Belden's 1694a. Pay LHS a visit and you suddenly find good value for money cables :p
I think the 1694a is a good buy. I am using 2 runs of that right now for my subs. Works great. I opted for the cheaper soldered RCA plug ($3 per piece), didn't want to spend too much on sub cables. Go try it out. I don;t think it's necessary to spend too much on sub cables.
2 runs? meaning u connect to left and right of your sub?
actualy is there any differents between subwoofer cable or component cable? if i combine 3 sub cable is equaly to a component cable right?
There is an important difference.  If you want your pictures to be clear/sharp, you should use the standard 75ohm high wandwidth cables for component only.  You can use other cables, but do not expect the best images.
Now the question is whether you can use component cable for sub, and the answer is yes.  Some are actually not bad in this application.
so this belden is speacialy for subwoofer or component? :)
General guide is true 75 ohms rated video cables can be used for either video and audio applications with good results. However, it is not recommended to substitute video cables with audio only type (unless proven good).
They close at 7pm on weekdays.  Also I prefer Canare LV77 as a sub cable.  It has better shielding and hum rejection which I feel is more important for a sub interconnect. Alittle more ex though.
Oliver
Oliver
so how much u brought ur canare LV77? :)
You know i seriously think you can get your answer(s) if you just call LHS...Robert is the guy u should look for. He is v helpful and friendly...
yes sir! i wil go down tomolo :)
when down to LHS, Robert indeed a very helpful guy, n also hardworking ler, cause i reach there at 745pm, the shop still open :)
got myself canare LV77S with canare RCA, he only need about less than 10 minutes to finish the cable, at first I thought the cable will be solder to the RCA? or just crimp will do? ???
