Hi all,
I'm currently using a step down transformer for my Toshiba HD-DVD player (import fm U.S), and was wondering if the transformer is compatible with a Japanese PS3? I was told the Japanese PS3 runs on 100V while my Toshiba is 120V. Any difference?
Japan is 100V, US is 110V IIRC
noted. so what does this mean? can a Jap set PS3 use the step down transformer as my Toshiba player?
Should be ok , I guess . Just make sure the power ratings on the transformer have enough juice for toshiba and PS3 . Wow, you bought the PS3?
I use same transformer for all jap gamesoles and US accesories + Amp . So far no problem .
But i will not hold any responsibility if anythings happens to your PS3 ;D
