hermanL Posted October 5, 2006 Posted October 5, 2006 Hi Guys, recently bought nachus 3188 to use.. but its controller when i press always interferr with my teac integrated amp.. so piss off.. then i buy a cheap universal remote hoping to solve the problem but in the end the nachus cant syn at all... hope u guys can help advise .. thanks
hermanL Posted October 7, 2006 Author Posted October 7, 2006 hi hi.. really no expert can advise..i try search universal remot and seems that those good ones are $150 above ah. hope someone can share experience... tks tks...
SiriuslyCold Posted October 7, 2006 Posted October 7, 2006 I think nobody can figure out what to do if your equipment shares the same remote control code; even if you use a universal remote for example it sends out code 1234 for on/off on the Nachus, and the TEAC also uses 1234 for on/off ... the only thing you can do is locate them at 90° angles to each other
hermanL Posted October 9, 2006 Author Posted October 9, 2006 Thanks alot pal... hmm really no cure.. how come Nachus dvd player so special.... sigh..... i tried the universal remote to syn.. just hoping that it can work n after 1hr of detection still cant syn with the nachus player
Pingu1624705792 Posted October 10, 2006 Posted October 10, 2006 I had the same problem with my Momitsu dvdp and Pioneer avr. The volume control on the avr will switch off the dvdp. Eventually replaced the dvdp.
Jag Posted October 10, 2006 Posted October 10, 2006 hermanl, There is no way to solve your problem. Get rid of the item thats the least painful to you.
hermanL Posted October 11, 2006 Author Posted October 11, 2006 thanks everyone, looks like i really no choice.. maybe dont use nachus dvdp lor.. recently i switch to use xbox360 vga at 1280x768 i think... wa low the graphic is at least 20% better than my nachus dvdp ahhh k thanks guy
