Yo Guys,
Just got a XR-57, need recommendation for Bi-Wire cables
1) what is good and resonable cost?
2) where to get them at best price?
I was looking at the QED Silver Anniversay XT Bi-Wire, is it good? where to get?
Thanks
Hi ,
I have a pair of Belden 1810A bi-wire and one for center speaker used for 1 week, PM me if you are interested.
thanks
LHS?? stand for??
LHS is a shop in Sim Lim Tower. 2nd floor #02-27 I think.
They carry many kinds of cables - from speaker cables to computer network cables...
i m using Belden for HT and Canare 4S11 for music as I find the Belden gives a "faster" sound, suitable for movies.  the Canare 4S11 gives very balanced and full body sound, so if u are using the system both for music and movies, then its a good choice.
if u decide on the Belden, go for the 14AWG (thicker) than the 17 AWG, give u a better sound also
btw what speakers are u using, becos matching is an issue.  give u an eg. i hv QED XT300, dont do too well with KEF or Energy but when i hook them up to Monitor Audio... its very good.
happy hunting.  :)
I have Monitor Audio S1 now, will try with the Xr-57 first. But thinking of upgrading to GS20 for the fronts.
Where can I find QED cables?
sorry to barge in on tis thread, any recommendations for single wire wires
for connecting xr55 to svs speakers? the canre 4s11 r bi wire but can be splitted
into single wires rite? also if i gettin beldens which model number cable is
recommended? also any good banana plugs to recommend or should i juz
get the 1s they r sellin at lhs? was tinkin of gettin those generic silver
coated copper cables frm kec which cost $2/m.
I'm using the 4S11 as single wire.. twisted the 2 red leads together & the same for the white... doing bare wire at the speaker ends & banana plugs (like the one in the small pic of the thread below) at the amp side..
http://www.xtremeplace.com/yabbse/index.php?topic=40906.0
Since the wires r quite thick, i discarded the silver colored ring & used heat shrink instead...
Did a short comparison between single lead vs double leads by connecting the surround as main speakers & listed to CD (stereo) & preferred the double leads. Never tried other cables for surround though...
for my HT front speakers, i m doing the same for Belden 17AWG, twisting 2 single cable to be used as one as i find the sound is better... don't know if its pyschological.  :)
I was thinking of  doing bi-amping for my mains, but how accurately must the length of the new cable be?
Would the woofs/tweets be out of phase if its just 2/3 mm longer/shorter than each other?
mucho gracias
mucho gracias
I don't think it matters. It is more physicological effect if there is.
Imagine if it does matter.. everybody go to LHS and ask them to use a precision ruler to measure and cut the cable.. damn jia lat liao....
FYI, my speaker cable are of different length for left and right.....
