daredevil_kk Posted August 7, 2006 Posted August 7, 2006 Anyone has it? ;D Any comments, where to buy and its price?
Madsumm Posted August 8, 2006 Posted August 8, 2006 You should be able to get it at Harvey. I think its just below $500. Rgds
Magnet1624705822 Posted August 11, 2006 Posted August 11, 2006 I bought it from Amazon earlier this year. including shipment is around $350
daredevil_kk Posted August 11, 2006 Author Posted August 11, 2006 Hi Magnet, Thanks, what is your feedback for it? BTW can it be program to control the Air-con as well? ;)
Magnet1624705822 Posted August 14, 2006 Posted August 14, 2006 Sorry for the late reply. Yes. Some of the common brand of air-cons are in the library setup. If not, you can always 'teach' the remote to learn your air-con commands. The remote is generally ok. I have also teach it to be able to control my starhub cable. One good feature is the activities feature where you could program it to turn on x number of devices by pressing just one button. Example, when I press watch TV, it will automatically turn on my TV, Starhuh cable and fan. Hope the above feedback helps.
Guest wcseow Posted August 14, 2006 Posted August 14, 2006 Hi Is there a way i could see what is in the library before I make the purchase. Run through the web site and it seemed not available thanks Sorry for the late reply. Yes. Some of the common brand of air-cons are in the library setup. If not, you can always 'teach' the remote to learn your air-con commands. The remote is generally ok. I have also teach it to be able to control my starhub cable. One good feature is the activities feature where you could program it to turn on x number of devices by pressing just one button. Example, when I press watch TV, it will automatically turn on my TV, Starhuh cable and fan. Hope the above feedback helps.
Magnet1624705822 Posted August 15, 2006 Posted August 15, 2006 Hi, You should be able to see. In fact, the library is very updated. It has most of the brand and models for TV, Home Theatre, etc. It even has the setting for my B&O Sound 1. Go to this website: http://www.logitech.com/index.cfm/products/features/harmony/US/EN,CRID=2078 and click on take a test drive.
Wolf1624705742 Posted September 1, 2006 Posted September 1, 2006 Hi, You should be able to see. In fact, the library is very updated. It has most of the brand and models for TV, Home Theatre, etc. It even has the setting for my B&O Sound 1. Go to this website: http://www.logitech.com/index.cfm/products/features/harmony/US/EN,CRID=2078 and click on take a test drive. do we need to install the software and all to see the list? Is there anywhere we can just view the list showing all library?
