Guest wcseow
Hi...here is my situation
Am doing reno on my current house and a new condo. Condo done and the house is stii undergoing reno...
I am re-using a number of my old HTS, receivers etc and previously all my speakers are on stand. Found it troublesome as the kids keep knocking them down. So in the new reno, I have the units design to have the rear speaker being wall mounted.
Now I got to go and "hunt" for the brackers as my id is totally clueless on that. She though it is mounted directly on the wall, in a horizontal position 406 feet above my head!!.
Pls let me know where I can go to buy the brackets. Have beern to several to DIY and all they sould does not seem suitable.
This is what I need
a.  wall mount for JVC S-11 HTS speakers. This speaker has a single hole or single screw. (pear shape)
b. Ceiling mount for  Creative 5.1 speaker system. Again these speakers has a single hole only (pear shape type)
c. House - Pioneer S-CR50A speakers (part of the V50A set)
pls let me know where I could go to shop for these
thakns
Guest wcseow
try some DIY store, say homefix
Hi
Have gone to many DIY stores oredi (Selfix, Homefix, etc..) still cannot find. Carried the same model and seems suitable for 4 holes type
tks
Monsoon has quite a number of them. KEC has 2 types.. clamp & screw in to the speakers.. SLT basement (right side of escalator when u come down) also has some brackets but not sure if they r for TVs or speakers. Another place is a second hand shop along Jalan besar.. only 1-2 types available. According to the gerl there, the brackets are new...
Guest wcseow
tks..will go SLT..
