soulster Posted June 6, 2006 Posted June 6, 2006 Help , no picture only sound after plug in video cable . what could be wrong with my crt tv , can anybody advise. Is it worth to repair ? Regards
DIRTRUN Posted June 6, 2006 Posted June 6, 2006 Hiya S, I am confused??? Help us a little here : 1. What source are you using ie from cable, dvdp or vcr? 2. After plug in what cable? If just composite(video-yellow, only one cable) then you shouldn't have sound even . Offhand have you got it set at the right channel usually it is video1 or 2? Cheers Dirtrun
soulster Posted June 6, 2006 Author Posted June 6, 2006 Thanks for your reply. I'm using dvdp and plug in using video and audio interconnect (single yellow, white and red) Channel set correctly as 2 days ago every thing was ok and I suspect video input problem. Just want to find out if I can get it repair and wether cost worthy or not.
DIRTRUN Posted June 6, 2006 Posted June 6, 2006 First, bro You need to check on whether your display is faulty, it could be your source(dvdp). Anyway can you get a small tv to check this out, pull out the composite cable and stick it in the other tv and see . Cheers. Dirtrun
soulster Posted June 7, 2006 Author Posted June 7, 2006 Thanks Dirtrun, you are right it's the source as I try my other dvdp it works well. Looks like I gotta get me another dvdp. Looking at one which play all disc , maybe you might be able to recommend. Peace Bro...
luminio Posted June 9, 2006 Posted June 9, 2006 Hello soulhock, looked like you have hit the progressive scan button on your remote!
DIRTRUN Posted June 12, 2006 Posted June 12, 2006 Thanks Dirtrun, you are right it's the source as I try my other dvdp it works well. Looks like I gotta get me another dvdp. Looking at one which play all disc , maybe you might be able to recommend. Peace Bro... Hiya, Philips and LG come to mind erhh for uhm compatibility issues.... Cheers. Dirtrun
