Hi,
My subwoofer suddenly have the "popping" whenever there is bass from the movie. And there's a loud "pomp" whenever I switch off the AC supply. I have check the speaker cone, it's was perfect, suspect something wrong internally. Just like to find out from you guys what's the problem, is there a cure beside replacing it with a new one ? Or can recommand any repair service ? Thanks.
Rgds
Mike
Most likely the internal amp is in need of servicing. You'll have to send it in for servicing. There's nothing much you can do from the outside. :)
Hi,
Just call them (Asia Sound Equipment) up and the charges was like $50(service) + $180-$200+(for the parts, driver). Is it worth ?
BTW, mine is the Polk Audio PSW 202 (3 yrs), my first in HT.
Hiya,
I guess it is up to you, how much  you like the Polk (sub) sound.
But (here it comes) for most people here spending 250 bucks denotes some form of upgrade, hehehe ;)
Dirtrun
Just like to find out how much does a decent 100w sub cost. Any recommandation ?
Hii... still undecide wheather to repair or get a new one. $$$$ very tight... hi.... ???  :'(
