Frens, need advise pse.
Thinking of buying 5.1 gallos micro, but want to buy another subwoofer. Any budget recommendations? Was thinking of buying the 10 in Wharfedale from SLS City Electronics - I rem it was quite cheap. But not sure if it would be able to complement the small size of the gallos speakers - would there be a drastic gap in terms of the mid and low freq range?
The ideal sub would be one which has a small footprint and tight bass - my budget is about $500.
Also need advise on a fuss free and easy to use AVR - one which also has a small footprint. Digital AVR is what I am looking for - but I know my budget of about 500 bucks is not going to cut it (I know - wishful thinking!!). Never mind - lets see wat is the general comments and advise.
BTW, will be posting in echo for more comments. Thanks.
actually $500 would have been enough to get a superb Panasonic XR55 shipped from the US. unfortunately they are sold out almost everywhere and you'd be lucky to find one. oh, wait hplanet selling 2 extra sets.. why don't u ask him
BTW, i'm also in two minds on the gallos and orbaudio...may i ask what is the asking price for the gallos?  Thanks in advance.
Gallos are quite expensive - about $200/speaker (not pair) IIRC. My advice would be to go for cheaper speakers like Wharfedale Diamond 9.0 (<$300/pair) so you will have more money for a decent sub and AVR. Need at least $500 for the sub and another $500 for the AVR. If you really must have tiny speakers, then would advise you to wait and save up another $500.
Don't buy those cheap Wharfedales at SLS - they are not good, hence the cheap price. Paradigm PS-1000 is good value for money if you can find it.
If your looking for good 5.1 satellites speaker that can perform for music & HT, try auditing the Cabasse Xo2 system available at Electrades Audio 4th floor Adelphi. Cost about $1.5k comes with all accessories eg: spk cables, brackets and stand...Oh! and its easy to drive 92dB.
http://www.cabasse.com
Cheers!  :D
Wow, that Cabasse system sure looks good! If it's as good as they claim it is (flat response 35-22000 Hz), then it's good value for money at $1.5k!
The specs mention that the satellites goes down to 200 (pretty high) while the sub handles 35-200. Other sat/sub systems you should consider auditioning are like the KEF KHT, Definitive Technology Pro-Cinema...
Thanks for all the comments. Still comtemplating.... but I bought a pioneer digital amp already C501-S. I know it is an old model but it is cheap - only $370.
