Hi! Just want to do a quick poll on this to see how popular is a remote control.
Keyboard with mouse is a standard PC setup.
Keyboard without mouse is more like a special keyboard which can be used solo (e.g. with trackball included, etc)
I just bought a remote actually, just because I'm so used to dvdp. It's the remote for MCE 2005 and I manage to get it working with normal XP. Wondering if other people enjoy this sort of flexibility? Or do you think a keyboard is a must for HTPC?
  • 2 months later...
I am looking for a remote control too,could you tell me what you bought and where to buy & how much.Thanks
I think you need another option. I use a keyboard with the built in mouse and a remote that came with my PVR-150. I use the keyboard a lot a the moment as I'm setting up, but I'll probably use the remote more once things are stable.
hi rider. i use the MCE 2005 remote as mentioned. can be purchased from a few places.
forget the price already.
htpc-gear.com shld have a set for sale.
Thanks for the info,will check it out.Cheers
