IGNORED
Placing Floor Stander on Top of Subwoofer
tinytok
 Share
bad bad idea...
imaging will go crazy...
worst case..u may see your speaker sliding off the subwoofer.
but if u don really bother much...why don't u try it out to see if u can tahan the sound?
what does "perfect" decoupling means ?
Does decoupling means to put a piece of material (e.g Marble Slab) on top the sub where the speaker will sit on ?
Well planning for another similar sub. But space constrain.
"decoupling" means keep them separated, so that the vibrations from one won't go to the other.
hm.. yeah.. probably putting a marble slab will help..not too sure..
 Share
