IGNORED
AVIA Guide to Home Theatre
Guest joamonte
 Share
Guest joamonte
thanks Jag
duckling,any idea what different between the content of"Sound & Vision Home Theater Tune-Up"and AVIA....
i try up the THX Video set up section in the X-man DVD but found that its useless...since many people said that AVIA is good i was thinking of take a try.....but if both DVD content are about the same,maybe i can save $50... ;D
Guest joamonte
thanks again duckling
i think i will get the AVIA coz tis test seem useful....
Grayscale & Levels
Needle Pulses
Needle Pulses + Steps
Black Bars + Log Steps
Black Bars
Black Bars + Half Gray
Black Bars + Half White
Vertical 10 IRE Steps
Horizontal 10 IRE Steps
Crossed Step Scale
Vertical Brightness Steps
Horizontal Brightness Steps
Vertical Gray Ramp
Horizontal Gray Ramp
Crossed Horizontal Gray Ramp
Crossed Vertical Gray Ramp
Black
10 IRE Window
20 IRE Window
30 IRE Window
40 IRE Window
50 IRE Window
60 IRE Window
70 IRE Window
80 IRE Window
90 IRE Window
100 IRE Window
20 IRE Window
Black Bars
10 IRE Field
20 IRE Field
30 IRE Field
40 IRE Field
50 IRE Field
60 IRE Field
70 IRE Field
80 IRE Field
90 IRE Field
100 IRE Field
Geometry and Convergence
Center Cross 30 IRE
Center Cross 50 IRE
Center Cross 100 IRE
Crosshatch 30 IRE
Crosshatch 50 IRE
Crosshatch 100 IRE
Crosshatch Inverse
Dot Hatch 30 IRE
Dot Hatch 50 IRE
Dot Hatch 100 IRE
Dot Hatch Inverse
Circle Hatch 30 IRE
Circle Hatch 50 IRE
Circle Hatch 100 IRE
Dots 30 IRE
Dots 50 IRE
Dots 100 IRE
Gray Field Dots
White Field Dots
Black Field Plus
Gray Field Plus
White Field Plus
Checkerboard 30 IRE
Checkerboard 50 IRE
Checkerboard 100 IRE
Letterbox Geometry
Crosshatch 1.66 30 IRE
Crosshatch 1.66 50 IRE
Crosshatch 1.66 100 IRE
Crosshatch 1.78 30 IRE
Crosshatch 1.78 50 IRE
Crosshatch 1.78 100 IRE
Crosshatch 1.85 30 IRE
Crosshatch 1.85 50 IRE
Crosshatch 1.85 100 IRE
Crosshatch 2.0 30 IRE
Crosshatch 2.0 50 IRE
Crosshatch 2.0 100 IRE
Crosshatch 2.35 30 IRE
Crosshatch 2.35 50 IRE
Crosshatch 2.35 100 IRE
Widescreen Enhanced
WSE Crosshatch 30 IRE
WSE Crosshatch 50 IRE
WSE Crosshatch 100 IRE
WSE Crosshatch Inverse
WSE Circle Hatch 30 IRE
WSE Circle Hatch 50 IRE
WSE Circle Hatch 100 IR
WSE Dot Hatch Inverse
WSE Dot Hatch 30 IRE
WSE Dot Hatch 50 IRE
WSE Dot Hatch 100 IRE
WSE Dots 30 IRE
WSE Dots 50 IRE
WSE Dots 100 IRE
WSE Resolution
Resolution
Resolution 100 TVL
Resolution 200 TVL
Sweep
Sweep 50%
Multiburst
Multiburst (Labeled)
Multiburst 50%
Multiburst 50% (Labeled)
Sharpness
Color Adjustment
Blue Bars
Red Bars
Green Bars
Split Color Bars
Split Bars with Gray
Crossed Bars
Minimum Phase Bars
Maximum Phase Bars
Full Bars
Split 100/75 Bars
Full 100 Bars
Split 100 Bars
Full 50 Bars
Split 50 Bars
Yellow Field
Cyan Field
Green Field
Red Field
Magenta Field
Blue Field
Special Tests
Color Decoder Check
Y/C Delay
Zone Plate
Moving Zone Plate
Moving Zone Plate (Low Bit Rate)
Gamma Chart
16 Rectangle
Overscan
Overscan Bounce
Pixel Cropping
Backlight Levels
Modulated Steps
Modulated Ramp
High Hot Spot 0% to 300%
Mid Hot Spot 0% to 300%
Low Hot Spot 0% to 300%
I've never used Sound & Vision Home Theater Tune Up disc before.
I use Avia and I found it slightly better than VE. Avia gives 3 colour-corect filters to properly adjust RGB field values.
AVIA's video test is technically sound. I feel actually more comprehensive than VE. Not sure about S&V thou.
Audio test.... I believe is not so important, but Avia is much much much better than THX optimode.
Most of the video test may not apply to digital pjs. They were designed for CRT pjs and TVs.
But you'll feel Avia is worth its price!
My prefence is: AVIA
Avia actually is better as it offers explanations on how to use its audio and video test patterns.
Video test is very comprehensive, audio test is great. But have to be careful and how u set it coz it can seem confusing initially.
But Avia doesn't have 6.1 calibration. But then Avia was published when DD-EX and DTS-ES were still lab experiments! :P
 Share
