IGNORED
help : aiwa turntable px-e860
Guest firezab
 Share
Guest firezab
hi
anyone have the above model turntable. Mine , the belt came off and I can't figure out how to put it back.
thanks
anthony
  • 6 years later...
Chances are that the TTs you guys mentioned have an inner rim on the platter that is visible via two slots (or more) near the outer rim.
First, place the belt on the inner rim. If your platter can be removed, do it and then mount the belt. Replace the platter on the TT.
Turn the platter so that one of the slots overlook the motor puller.
Then with a straightened paperclip (other other similar implements) try and pull the belt from the rim over to the motor pulley.
Anyway, photos help if you have any.
 Share
