Calvin83 Posted June 4, 2002 Share Posted June 4, 2002 How do I go about getting Dolby 2.1 to work? Whenever I play Dobly 2.1, I can only switch between Prologic or Prologic II? I can't seem to find how to go about disabling Prologic/Prologic II on the receiver. Can someone kindly enlighten? Thank you. Link to comment Share on other sites More sharing options...
Jag Posted June 4, 2002 Share Posted June 4, 2002 On my yammy 2200, turn off "effects" to listen to plain stereo. Btw, Dolby 2.1 is a term never used. The "2.1" numerology indicates "2" discrete channels + a "0.1" bass channel. Look up ur manual on how to turn on/off effects. Good luck! Link to comment Share on other sites More sharing options...
Calvin83 Posted June 4, 2002 Author Share Posted June 4, 2002 Thanks for the correction, so I supposed it's called Dobly Surround? Hmm, what is the meaning of stereo? It means only the 2 main speakers right? So when I change to stereo mode, it is Dobly Surround? Actually I knew of the stereo mode, but I thought maybe there's another mode for Dobly Surround. ??? Link to comment Share on other sites More sharing options...
