Mr.Anderson Posted February 24, 2021 Share Posted February 24, 2021 (edited) Hi All, Looking for a Cabinet Maker who can repair my REL R505 Subwoofer. I shipped it from London but when it arrived I noticed that all 4 feet have been wrenched off due to someone not being careful with handling it. I should've known better to ship it upside down. . Luckily everything else seems unharmed and intact. I think either we can go the easy way and paste the feet back with some good MDF glue, or go the hard way by removing the entire bottom plate and putting a new piece of MDF there. Any advice is welcome. Cheers Edited February 24, 2021 by Mr.Anderson Link to comment Share on other sites More sharing options...
GregWormald Posted February 27, 2021 Share Posted February 27, 2021 As long as it sounds OK, I'd recommend some good glue. 1 Link to comment Share on other sites More sharing options...
Bisguittin Posted February 28, 2021 Share Posted February 28, 2021 Go the glue path. The breaks look clean and should remarry very easily. I would personally use Titebond Original Glue for this exercise. Link to comment Share on other sites More sharing options...
tktran Posted February 28, 2021 Share Posted February 28, 2021 PVA glue is stronger than MDF. I once tested a 18mm MDF butt joint using PVA glue. Then tried to snap the two pieces where they were glued together. Well, the MDF snapped. The glued joint stayed put. Just clean the edges, appy the PVA glue, clamp both edges for 24 hours, and you're good to go., 2 Link to comment Share on other sites More sharing options...
