Item: Odyssey Stratos Extreme 240 volt.
Price: $1600
Item Condition: Excellent
Reason for selling: Spare
Payment Method: Pickup/Ship Cash, COD, Bank Deposit, Paypal if buyer pays fees Only
Extra Info:
Save about $700 on this 4 month old unit. One owner who upgraded in the Odyssey range.
As well as sounding spectacular, this is one of the nicest looking amps I have seen.
Stratos Stereo:
base model specifications:
  • $1,195 USD
  • 2 x 150 Watts RMS @ 8 Ohms
  • 2 Ohm load stable
  • Class A/AB
  • 2 - 400,000 Hz frequency range
  • 60,000µF memory
  • 45 amps current delivery
  • <0.04% THD (not audible)
  • >500 continuous damping factor
  • Input impedance 22K ohms
  • DC offset <1 mV
  • RCA & XLR (bridged) inputs
  • 400 VA Plitron transformer
  • Sanken Epitaxial Planar Transistors 2SA1216 & 2SC2922
  • Anti vibration dual thickness PCB
  • Power consumption when idle ±30Watts
  • 4 internal fuses 250V/6.3A, 5x20mm, fast blow
  • Additional electrical protection fuse
  • 54 lbs weight / 24.5 kg
  • Dimensions: 19 width x 18 deep x 7 height (in) /
    48.3 width x 45.7 deep x 17.8 height (cm)
Stratos Stereo Plus:
improvements over base model:
  • $ 1,400 USD
  • Additional 60,000µF memory bank for 120,000µF total
  • 55 lbs / 25 kg weight
Stratos Stereo Extreme:
improvements over Plus model:
  • $ 1,750 USD
  • Additional 60,000µF memory bank for 180,000µF total
  • >60 amps current delivery
  • Additional 400 VA Plitron transformer for 800VA total
  • Higher performance parts:
    Nichicon Muse capacitors, Vishay/Dale resistors, extra WIMA metal film capacitors
  • Power consumption when idle ±35Watts
  • 70 lbs / 32 kg weight
Pictures:
  • 1 month later...
Or, may swap for vintage/interesting speakers and/or amplifiers .... ?
'Nutz
Hi 'Nutz, Is the Odyssey still on the market? cheers, Ivan
