FS: (ADEL) 120watt Dual Mono - Pure Class A - Power Amp
Item Condition: Good Condition
Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost.
Suburb or Town: Adelaide Hills
State: South Australia
Payment Method: Paypal, EFT, Cash on Pickup
Reason for selling: Funding new HT Receiver
This Pure Class A power Amp has a smooth and non fatiguing tone that rarely exists in a solid state amp. Its non-aggressive and deeply involving music reproduction makes it hard to believe it is not a valve amplifier. From human voice to acoustic instruments to rock, this amp loves every note you feed it and plays them faithfully as its instructed.
It is refined, subtle, and still managers to drive the majority of speakers effortlessly. Accurate and pleasing music is produced, regardless of the the genre.
The Amp employs dual mono symmetrical design with each channel driven by 8 Toshiba power MOSFET transistors. It also has an integrated DC servo circuit for Speaker Protection. The Electrolytic capacitors in the signal path are audiophile grade capacitors by either ELNA Silmic or Nichicon Muse KZ. Each channel is powered by a separate 500va Transformer and the filtration capacitors are the highest grade RIFA PFH169 series. The Tank like solid chassis for this nearly 30kg beast houses quality audiophile grade components purposely designed to work well together.
Power Output: 60 watts into 8ohm. 120 watts into 4 ohm (Pure Class A)
Dimensions: 485 x 430 x 165 (W x D x H)
Weight: 28kg
Would prefer a Local Buyer with pickup and inspection. Will take offers.
Dual 500va transformer means high current on low inpendece speaker should drive at ease. Glwts, little off the topic, to whom may curious what does transformer lable says - Wuhan Shinkansen Electronic Manufactory, and the colour of wiring config
1 minute ago, gemini07 said:
What brand is this?
Can you advise how old it is / how long you've owned it?
Cheers.
It's LITE, a diy kit manufactory based in Guangdong, China,, just some light research has found, the amplifier board (a80), transformer and chassis alone would cost around 4200rmb which is 840aud when new, in China. Hope my Chinese can help anyone who interest in this deal.
Hi,
Thanks for that information - very considerate of you.
Hopefully the owner can let me know how old it is etc.
Cheers,
G
Btw, they also sell the assembled unit, however this amp board is not a shelf config and therefore there is no ref price available for you, but at least we know this could be a factory assembled unit. Also, this brand seems copy some famous brand's circuit design, and make them to the Chinese market. Not saying this is good or bad, but certianly can consider it coukd be a bargian on bang for the buck. Anyway, good luck.
I am second owner. Im not sure of age but doesn't seem too old. I am using it in a HT system at moment to power the fronts in a 7.2 receiver. I am replacing everything with a single 11 channel Atmos receiver to power all my speakers.
As a comparison this replaced an Anthem Intetgrated 225, and the difference is this has a more holographic 3D presentation.
I don't think this is a Pass clone. They mention "Manhattan circuit" in their description and I can't see the link to Pass Labs there. As with many DIY class A designs it seems to be a MOSFET-based amplifier though. The revised iteration of this A80 is called an A88 and the schematic for that one is available online. I'd be interested to know how many watts it draws from the wall at idle to determine how much class A bias the designer decided to run in that chassis and what kind of temperature it idles at, as this is a matter for personal choice as well as technical considerations, to a degree. Do you have a link to any more information @360Cisitalia ? I'm keen to apply some google translating to the documentation and learn a little more about it. ?
Edited by treuben
http://www.lite8.com/product.php?action=1489
Let me know if you need any help
20170311_135401.thumb.jpg.eb8d0ec195513a3f95df557358fc76c6.jpgI had one before, got it pre-bulit.
Very nice amp.
The link don't work any more, but I save the information
http://www.diyfidelity.com.au/product_info.php?cPath=0_22&products_id=47
60 Watts Pure Class A Power Amp
 Price:     AUD$1,450.00  (GST included)
This 60W pure Class A power amp has a smooth and non-fatiguing tone that rarely exists in solid state amp. Its non-aggressive and deeply involving music reproduction makes it really hard to believe it is not a valve amplifier. From human voice to acoustic instruments to rock, this amp just loves every note you feed in and plays them right everytime. It is refined, subtle and above all it drives speakers effortlessly. If music is what you after, regardless the prestigious name of the big player, this amp is for you.
This amp employs dual mono symetrical design. Each channel is driven by 8 Toshiba power MOSFET transistors. It also has a integrated DC servo circuit for speaker protection. The electrolytic capacitors in signal path are audio grade capacitors, either ELNA Silmic or Nichicon Muse KZ. Each channel is powered by a separate 500VA transformers and the filtration capacitors are the highest quality RIFA PEH169 series. The tank-like solid chassis is purposely designed for this gentle giant. These are highest quality components that are rarely found in a commercial product.
    Power Output:         60 watts into 8 ohm, 120 watts into 4 ohm
    Class:         Pure Class A
    Dimension:         485 x 430 x 160 (W x D x H)
    Weight:         25kg
So it uses 150watts at the wall at idle .
It is warmish on the sides when it starts sounding its best but definitely not hot.  From this I would say it wouldn't compete with a Pass Labs.
Has to draw more than 150 watts if it is 60 watts per channel class A.
My 25 watt per channel class A amp draws 160 watts ftom the mains.
  • Similar Content
    • By muzzagruzz
      Item Condition: Excellent Shipping Options: Shipping is available at agreed cost. Suburb or Town: Miranda State: NSW Payment Method: EFT Reason for selling: NLR Further information:
      Free delivery in Sutherland Shire LGA!
      This has the balance of five years warranty.
      Selling this beautiful, as new, VPI Prime turntable that I purchased in August 2018 from Krispy Audio.
      This is a supremely quiet turntable that extracts every detail and nuance from vinyl recordings. The motor is dead quiet and spins the heavy 10kg platter very quickly and accurately.
      Beautifully made as with all VPI Industries turntables. This example is in as new condition - no marks or scratches anywhere to be seen as I look after my equipment.
      Technical specifications:
      Chassis Composition: Vinyl Wrapped MDF and Steel
      Platter Type & Size: 12" Aluminum, 20lbs
      Tonearm Included: JMW-10-3D Tonearm
      Motor RPM: 300 RPM (this could be 600 RPM in Australian examples?)
      Motor Pulley Accuracy: +/- .0005"
      Wow and Flutter:  .05%
      Speed Accuracy:  .05%
      Rumble: 80 db Down
      Footprint: 19 ½" x 13 ¾"
      Overall Size: 21 ⅜" x 15 ¾"
      Total Weight: 44lbs
      Comes with all inclusions: record clamp; instructions; box
      Cartridge and Nordost tonearm cable in the photos not included.
      Photos:
      PLEASE READ
    • By muzzagruzz
      Item Condition: Mint Shipping Options: Shipping is available at agreed cost. Suburb or Town: Miranda State: NSW Payment Method: Cash EFT Reason for selling: NLR Further information:
      Purchased new by me from Addicted to Audio to store my Focal Elear headphones. I stuck the headphones in them and shoved it in a draw and that's basically where it stayed.
      Perfect condition, no marks.
      Comes with original box.
      Photo with headphones for illustration only. Not included in the sale (just in case you were wondering).
      Photos:
      PLEASE READ
    • By foryou
      Item Condition: as new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Doncaster State: VIC Payment Method: Paypal (via F&F or buyer pay paypal fees ) , EFT, Cash on Pickup Reason for selling: fund for new amp Further information:
      McChanson 6L6 Tube amp
      bought new form Eric last year
      some special order with this amp
      Silk Output Transformer and Duelund cable for speaker output
      mono design with two mono volume pot (  TKD P-2511 100K MONO Attenuator  X 2 )
      mundorf supreme silver gold oil 0.47uf X 2
      speaker output 8/16ohm but you can change it to 4ohm /8ohm
      Ultra Linear / Triode (SET) switchable with adjustable fixed bias
      Two RCA input
      mainly use it as Power amp with Tannoy / Lowther speaker
      come with syetlans 6550c X3 and RCA 6L6  , 2 set of input tube , also rectifier tube
      10w-12w power ouput for 6L6 tube
      but if you use Kt66/Kt88 or Kt90 the power will increase
      Photos:
      PLEASE READ
    • By studer30
      Item Condition: Used Shipping Options: Shipping is available at agreed cost. Suburb or Town: Brisbane State: QLD Payment Method: Money Reason for selling: Thinning the collection. Further information:
      On offer is  Aiwa AD-F990 cassette decks. Comes one T200 remote. These were optional extras but come as part of the sale.
      The decks themselves function very well and are a technical tour-de-force featuring the following functions:
      Amorphous Tape Heads and dual capstans Automatic Tape Calibration Automatic Tape Type Selection Automatic Record Level Setting Built in demagnetizer Real time and Linear tape timer Dolby B and C Dolby HX Pro Automatic NR Detection (Deck automatically detects and switches to the type of NR used on the tape ) Large format Fluorescent Display Full Logic Transport Controls and more.
      Here’s a good place that gives a run down on these wonderful sounding machines :
       https://www.cassettedeck.org/aiwa/ad-f990
      Was part of a collection and very gently used. Deck have been previously serviced and all belts have been replaced. All functions work when tested. The silver top has some dings on the cover. This is purely cosmetic. The deck has a full bodied sound and presentation that delivers energy when the music calls for it. Top of the line  sounding machine with a wonderful sound and plenty of convenience features.
      The Black version has been sold. Only the Silver one is available.
      Photos:
      PLEASE READ
    • By foryou
      Item Condition: as new Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Doncaster State: VIC Payment Method: Paypal (via F&F or buyer pay paypal fees ) , EFT, Cash on Pickup Reason for selling: fund for new amp Further information:
      Up for sale as New XTZ EDGE A2-300
      Huge power from this amp
      one of the Best Buy power amp in budget
      Perfect size and great upgrade
      the amp still in 1 year warranty
      If you have two of it , you can run it bi-amp as mono block
      Free shipping
      https://www.xtzsound.eu/product/edge-a2-300
      Photos:
      PLEASE READ
