DIY Power Cable with US Power Plug
Spider27
 Share
Hello.
I have a couple of good quality US Main Plug that I would like to try. Yep, I understand that it is not recommended to use International Power Plug other than AU plug and it can void insurance but want to try it anyhow .  I have universal Power Strip so US Plug will fit fine.
One thing that I am unsure is polarity of US Power Plug. It looks like reversed the phase. AU power plug has usually left is Live and Right is Neutral. But US Plug indicates opposite, meaning Left is Neutral and Right is Live.  In this case, is it recommended to ignore what US Plug indicates and wire them as AU power plug does since I am using it in Australia?
Any guidance would be greatly appreciated. Thank you.
There is your clue that this is unwise.
An AU socket has the Active terminal on the left when looking at the socket from the plug side.
An AU plug has the Active terminal on the right when looking from the prong side.
My guidance would be that you need to ask an electrician to do this work for you and issue you a certificate of electrical safety.
Thank you and Yes, that is how I understood how to wire the AU power plug. Is it supposed to be wired with US power plug to be used in AU environment?
You need to maintain the correct AC input arrangement for the equipment you are powering.
In Australia that would be that the Active line is switched if a single plole poweer switch is fitted.
Thatt would also be that the Active line is fused if the equipment is fitted with a mains fuse.
Your universal powerboard may or may not maintain the correct Active and Neutral positions, have you checked?
Why do you use a universal socket powerboard? It seems likely to have less sucure contact and retention of AU plugs than a proper AU powersocket would.
Hi Peter. Thank you for the info.
I just wired same way as AU plug does (Active terminal on the left when looking at the socket from the plug side) and it seems working fine and amp runs quietly and sounds good to me. I would be nervous if I do what US plug indicates because it is opposite to what AU plug normally does.
I am using Consonance PW-3. The reason for using this is because it sounds noticeably better than other AU powerboard that I have tried.
Most of AU powerboard that I have tried has filter built in and it degrade the sound for me.
I heard that Isotek powerboard is better but it is a bit too expensive for me and might need a bit more time to save funds to try that one.
Just now, Spider27 said:
One thing noticed is that US Plug fits tight and better contact into PW-3 universal powerboard than plugging AU Plug into it.
I'm not surprised - the design of those universal outlets are a compromise when it comes to AU plugs.
The US plug is designed to work on a 115V system.  In Australia you will be putting 240V+ through it.  Not advisable at all, because you could burn your house down.  Unless you are feeding it 115V through an appropriate step-down transformer.  Any any work on mains power needs to be done by a registered electrician, so that the electrical system is safe to protect people's lives.
Not what you wanted to hear, but someone needed to say it (thinking of your safety).
Edited by audiofeline
Thank you for your feedback.
We are talking about power cable plug that has 3 pin metal pins with housing... no electronics.... It is a bit hard to believe that it requires step down  transformer to use US plug power cable that IEC socket on the other end.
Does it mean that we need to use step down transformer to use this type of cable?
Edited by Spider27
What you've done is correct.
Plugs, sockets, insulation, etc. are all rated to be used with different voltages.  Put higher voltages through it and it becomes unsafe - the insulation can't contain the voltage, or it melts.  The US plugs are designed to be used on 115V systems or lower.  Aust. plugs are rated for a 240V system.
So it would be relatively safe (but probably against code) if you were in the 115V US wanting to use a 240V Aust. plug, because you will be using a lower voltage than it's maximum.  But 240V is over double what the 115V US plug is designed for.
Please ignore people that post idiotic comments without having any knowledge of electronics. You are on the right path and if you want to experiment and take responsibility for your actions continue as planned. You are right, you have to wire your US plugs as you would normally do with a standard AU plug. When facing your plug - left is N - right is L - down is ground.
And a word of wisdom to some of the comments - the voltage does not burn your house down - stupidity and excess current do. Therefore, if anything, US plug current rating of 15A  is safer to use on AU mains network than the standard AU plugs. Voltage drives your insulation thickness choice and that is mainly applicable to cables since all plugs have enough insulation thickness for much higher voltage than 240V.
  • Like 6
  • Haha 1
And this is why I made the nonsensical suggestion to get an actual electrician to change the plug and issue a certificate of electrical safety. No electrician who follows the rules would do that. As noted above, 240V on a plug rated for 115V is not sensible.
The idea that a USA or UK power socket and plug is somehow audibly superior to an Australian plug and socket is ridiculous beyond belief.
... and to add, to support the naysayers - what is the main safety difference between US and AU plugs - and where AU plugs are generally safer than most of the other ones is plastic rings around the L and N prongs. This prevents incidental shorting of the lines if the plug is not pushed all the way in the socket and something conductive drops in the gap. However small probability of that happening - it can happen. The US plugs do not have that.
Unfortunately, both country standards specify ground prong to be oriented down (anthropomorphic tendencies I guess). The opposite orientation would increase safety of both designs, but would be much more beneficial to the US plug,
Edited by Decky
Maybe it is not fair comparison and it is what I currently have.
The cable made earlier today is made of Oyaide IEC socket and extremely solidly built US power plug. The cable itself is sourced from AU electrical wholesaler which is very thick and heavy.
The top AU power plug sealed is sourced from JayCar and it looks like a toy comparing with US power plug...
I will eventually change US plug to proper heavy duty AU one as soon as I source a good alternative one. For the time being, will try this cable as they are with US power plug for short term testing purpose.  Hope my house still stands during the testing period .....
Edited by Spider27
The Clipsal 56P10 might work if your diameter is 11mm or less. If you remove the orange inner ring it will do 14mm. That is a proper AU plug.
I found the $129 Belkin Pro Series 4000 to be very good and for me had better dynamics and power than the Isotek Polaris, and is very clean sounding. Gave me a wide and deeper soundstage than other power boards.
Correct, S - the top Au plug is a standard back-entry Aus plug.  Except it's a Jaycar Chinese-made plug - not a 'genuine Oz' Clipsal / HPM plug.
I doubt that the thick cable in your pic can be used with the Aus plug shown - the overall diameter of the wire and the guage of the conductors just won't fit.
I  use HPM 106/2WE (heavy duty, side entry) plugs in the power cables I make from thick (4mm ^2) flex.
Andy
Andy
Hi Andy. Thank you for the suggestion. I just googled it and it looks very similar to the one that I also got from JayCar the other day. (Here is the photo :) ) I have not seen HPM one physically but this JayCar Side Entry one looks very cheap too comparing with heavy duty Clipsal one recommended or US plugs shown.
Andy
Hi, Andy. May I know what power cable that you use to make your own cable?  The one that I have is very sturdy and well made and lots of copper inside but very stiff and not flexible at all. ?
Thank you very much for the suggestion. I might try it for myself soon.  I tried THOR powerboard and they were a bit disappointment.
Yes I didn’t want to mention that one, it killed the dynamics and compressed the soundstage. The Belkin was much much better and has remained in my system.
as @Deckysays
The higher AU mains voltage means lower current, less heat...V= I x R, Power = V x I etc...
...I will admit I'm a complete disbeliever that a power cord can make any "audible" difference though...
...any "kettle" cord is fine from my perspective.
mike
Edited by almikel
clarification
You are definitely saving yourself lots of money being a "complete disbeliever".
From my own positive experience, I am a believer and have enjoyed the performance improvements  that many upgrades to my system's at times more than dozen power cables have yielded over the last 25 years.  And I have been using US plugs for the last 20 years or so and nothing has ever got barely warm to the touch let alone hot enough to melt or burn...
Sincere question to all – has anyone known of a fire to be started or a house actually burned down from US AC power connectors  being used in residential scenario Australia?  I know the thought is truly diabolical and I would never wish it upon anyone but has it ever actually happened?
Edited by Aperalim
typo
 Share
