Help - Turntable Hum at high volume
CamHig81
 Share
Hi.
I was hoping someone in this forum could assist me with my issue. When I play a record and turn the volume up (albeit probably too loud but that's me) I get a loud hum similar to an earthing hum from the speakers. I don't get this when it's at lower volume, or when I play something through spotify over wifi. My kit is as follows:
- Yamaha R-N303D receiver;
- Pro-Ject Primary E Phone; with
- Re-furbished Sansui SP-50 speakers running a new 3-way Dayton Audio drivers.
My initial thought is the pre-amp in the turntable is not enough to handle high volumes, as i said before, wifi music works beautifully. I'd like to exhaust any possibile cause before potentially purchasing either a new receiver with a built-in phono stage, or an independant pre-amp.
Any help or suggestions would be appreciated.
Sounds like something your cartridge/arm us picking up.
It will be there at low volumes but your just not noticing it.
Probably not an earth issue but more likely a hum picked up from a motor or power supply.
Try moving the TT relative to such hum emitters.
Try it without the needle on a record and move the arm.
Does the hum alter?
3 hours ago, eman said:
I'd say Acoustic Feedback.
The TT is picking up the 'music' from the speakers.
Less volume or move the TT away from the speaker/s.
Might be but feedback is more a howl than a hum and it really takes off in a big way.
"Loud hum" when he turns it up tho.
OP  has both our suggestions to try at least.
I had a similar scenario when my amp was plugged into a different circuit to my cd player, had a dedicated circuit run from the fuse box to my amp, is your system powered from the same power point? Good luck my friend ?
 Share
