FS: Klipsch Reference Series RF-25 Floorstanding, RC-25 Centre & RB-15 Bookshelves
Item: Klipsch Reference Series RF-25 Floorstanding, RC-25 Centre & RB-15 Bookshelves
Aspendale (Vic)
Price: $950 Negotiable. 3.5% of sale price will be donated to SNA.
Item Condition: Very Good to Excellent. Small amount of vinyl wrap has lifted slightly on the front corners of the RF-25 floorstanding speakers (see photos). This is purely cosmetic and doesn’t impact the performance of these speakers and could be easily fixed with a little care.
Reason for selling: Upgrading and need funds
Payment Method: Paypal, Cash on Pickup
Extra Info:
These speakers have been used for both home theatre and music listening. Klipsch speakers are perfect for movies and music, particularly rock/pop style of music. These speakers are very efficient meaning they can be played loud without needing a high powered amplifier to drive them.
All speaker cabinets are in great condition.  There is a small amount of vinyl wrap that has lifted slightly on the front corners of the RF-25 floorstanding speakers (see photos). This is purely cosmetic and doesn’t impact the performance of these speakers and could be easily fixed with a little care.
More importantly the speaker cones/drivers are in excellent condition. These speakers have been used in a small 2 bedroom unit so they have never been driven hard or used to their fullest potential. There are no marks/dents on the speaker cones as they have always been used with the speaker grills in place.
The RF-25 floorstanding speaker comes with dual 6.5-inch (165mm) woofers offering great bass for their size. Comes with spiked and rubber feet to suit soft or hard surfaces. Can be bi-wired.
The RC-25 centre speaker is front ported allowing it to be installed in a cabinet or flush up against a wall without loss of sound quality. Comes with an adjustable foot to allow the speaker to be tilted up or down so that it can be “aimed” to the listening area.
The RB-15 bookshelf speakers have been used as the rear channels to form a 5.1 surround setup with the aforementioned speakers. The rear panel has both keyhole and threaded insert allowing them to be easily mounted to walls or attachment using wall/ceiling brackets.
Would prefer to sell these speakers as a set since it would make an ideal home theatre starter package, only requiring a subwoofer of your choice to be added. However I will consider selling the components separately upon request.
Inspections welcomed.
Quick Spec's:
RF-25 Floorstanding Speaker
  • Bandwidth:  45Hz-20kHz ± 3dB
  • Sensitivity:  97dB @ 2.83 volts/1 meter
  • Crossover Frequency: 2633Hz
  • Power Handling: 125 watts (500 watts peak)
  • Enclosure Type: Bass-reflex via rear-firing port
  • Drive Components: Two way system using one 1'' (2.5cm) magnetically shielded, titanium dome compression driver with an integral 6'' (15.2cm) square 90°x60° Tractrix Horn and two 6.5'' (16.5cm) magnetically shielded, Cerametallic cone woofers
  • Weight: 20kg
  • Height: 98.8cm with feet
  • Width: 21.6cm
  • Depth: 35cm
RC-25 Centre Speaker
  • Bandwidth: 69Hz-20kHz ± 3dB
  • Sensitivity: 95dB @ 2.83 volts/1 meter
  • Crossover Frequency: 250Hz and 2250Hz (Tapered Array)
  • Enclosure Type: Bass reflex via dual front-firing ports
  • Drive Components: Tapered Array system using one 1'' (2.5cm) magnetically shielded, titanium dome compression driver with an integral 5'' (12.7cm) square 90°x 60° Tractrix Horn and two 5.25'' (13.3cm) magnetically shielded, Cerametallic cone woofers
  • Weight: 8.6kg
  • Height: 16.5cm
  • Width: 52.1cm
RB-15 Two-Way Bookshelf Loudspeaker
  • Bandwidth: 70Hz-20kHz ± 3dB
  • Sensitivity: 93dB @ 2.83 volts/1 meter
  • Crossover Frequency: 2840Hz
  • Power Handling: 75 watts (300 watts peak)
  • Drive Components: Two way system using one 1'' (2.5cm) magnetically shielded, titanium dome compression driver with an integral 5'' (12.7cm) square 90°x 60° Tractrix Horn and one 5.25''  13.3cm) magnetically shielded, Cerametallic cone woofer
  • Weight: 4.1kg
  • Height: 28.5cm
  • Width: 16.5cm
  • Depth: 19.8cm
