Guest crankit Posted February 4, 2020 Posted February 4, 2020 Item: Ghentaudio GA-M500P Monoblock Power Amplifiers Location: Perth Price: $1000 Item Condition: Excellent Reason for selling: Funds Payment Method: Pickup - Cash, Bank deposit Extra Info: As new condition and working great, about 1.5 years old From GhentAudio website: RRP $675.00 USD each + GST + Import duties Black machined feet fitted, original silver feet included Free post Australia wide in original box and packing Main Features Well designed for Mono-Block, based on the latest ICEpower Class-D technology Mono-Block 500w(4Ω), or 250w(8Ω), via Balanced XLR & RCA inputs Latest design of buffer stage, high-bandwith & high impedance, suitable for most of pre-amps More balance, more detail, no noise, neutral sonic coloration Led Color for choosing: Blue, Green, Orange and White Led Dimmer: Led brightness could be adjusted manually "Brighter | Normal brightness | Power-off" Hi-End Neutrik & CMC components, silver-plated Teflon signal wire inside 100% Aluminum case, perfect Brushed carftwork & Laser Inscription, excellent cooling performance Well assembled & carefully tuned, Ready-to-Play Power Supply: 115VAC or 230VAC 50/60 Hz (Pre-Setting in factory, according to voltage choice) Key Specifications Latest buffer-stage, specific Mono design, powered by ICEpower technology Input connections: Single-ended RCA or balanced XLR RCA input impedance: 100Kohms Balanced input impedance: 200Kohms Maximum Power Output: 500w 4 ohms, 250w 8 ohms Power Output 1% THD: 450w 4 ohms, 225w 8 ohms Minimum Load: 3 ohms per channel Peak Output Current: 30 amperes Frequency Response: /- 0.15dB 20Hz-20KHz, All loads THD N: 0.003% 1W, 100Hz, 4 ohms IMD (CCIF): 0.0009%, 10W, f =18.5kHz, 1kHz, PO =10W Output Noise: 30uVRMS A-weighted 10Hz-20KHz Voltage gain:: 30.7dB Damping factor: >1000 Dynamic Range: 121dB Sensitivity: 1.42Volts Power On usage: 9.5W Power Off usage: 0.0W Protection: Short circuit, Thermal & Over-current protection Size: 200 x 80 x 210mm (W x H x D) Weight: 4.4lbs, 2.0Kg Warranty: Two years for original owner Designed and Manufactured in Shanghai, China Photos: Advertisements without photos of the actual item will not be approved.
