Hi All,
Just wondering if anyone is running or listened to a good sub that is either wall mounted or inwall.
My media room is small - 3 x 4.5m. I currently have 2 B&W PV1's that do a great job, but I just went to onwall speakers and would like to get everything off the floor for space purposes. The room will be used as a lounge also, as well as a media room so I'd like to get as much installed stealth as I can.
REL don't seem to make the Habitat anymore, and Paradigm have the Millenia but not sure on any other options.
Any recommendations?
Corza
What about something a bit more integrated such as the VAF platform?
Have also seen some DIY builds where the subs are built into side tables to be concealed in plain sight in a lounge setting.
