Pickup would be great on these items but especially the Yamaha as it is very heavy. Apologies for quality of photos. Can post
at buyers expense though.
Item:  Yamaha MX-1000 Power Amplifier
Price: $1200
Item Condition:  good 7/10
Reason for selling: Cleanup
Payment Method: Pickup - Cash
Extra Info: Good condition, some marks on top, small scratch on the display about 5mm long (can feel with fingernail)
As far as i know the only mod done to this is changing power cable to a longer one.
The only issue i know of is the led display isn't working (common issue), been told possibly a 12v regulator or need
need to replace leds. Amplifier itself works fine.
Item: Luxman C-02 Pre-Amplifier
Price: $750
Item Condition: Good 7-8/10
Reason for selling: As Above
Extra Info:  Nice condition, few minor marks
Have been using this on and off past few years no problems, until about 2 months ago. I plugged it into a crappy power board
i have, switched on the lux and the powerboard fizzled (board went straight to the bin), pretty sure after that i plugged it into
another board and it didn't come on. Tried it in another board and then it worked ok, since then have used it a reasonable amount
and it's been working fine, so not sure if something may have happened with the power supply on the lux? but just thought I'd put on that
info in so an informed decision can be made.
Item: Ikea stereo cabinet (corras??) or bedside (see first photo)
Price: $10
Item Condition: fair, as most ikea stuff its chipboard/mdf and does have a small bit of swelling on the top.
Extra Info:  popular ikea unit used for stereo gear especially naim. can put a cd player on the shelf and records
will fit under. Should have the wheels for it as well but can confirm that if required.
20191203_065840.thumb.jpg.43801f80f13392e738ed8a38bc540050.jpg20191203_070006.thumb.jpg.66e449fe7df07be8b2bde8ede502ab50.jpg20191203_070100.thumb.jpg.3ca2412dbd40ac55e4f543f1098945c1.jpg20191203_070139.thumb.jpg.254c478187dac8198b5f570a96f5b69e.jpg20191203_070330.jpg.ff941eeef34b38c1632f3f039e5f2000.jpg20191203_064124.thumb.jpg.a1c23aecc8d1abb7eeb2b5b1c6cb77cf.jpg20191203_064209.thumb.jpg.c65f42596be5b27ee5826d2023b913f9.jpg20191203_064230.thumb.jpg.38b4c95501e5e63e7aa32f9e80099c6d.jpg20191203_064251.jpg.4dd69b59a1c08bc9de8ad6f55f6ca953.jpg20191203_064326.jpg.8525e6cc7578d990dfe05f00eb11dd9c.jpg
Edited by Swordsaint
Have original box for the Yamaha but it doesn't have the foam inserts although sure i locate something that will work instead and pack well
if post required.
PRICE DROP:
YAMAHA $1050
LUXMAN $700
Despite what's been written above about the Lux i believe it's fine, have been using daily for a few hours
since this listing and been working like a dream
See other ads for Rega Saturn.
