Item: xDuoo TA-01
Price: $85 + $15 postage
Item Condition: Good used condition
Reason for selling: No longer needed
Extra Info:
I purchased this dac/amp to use with my Beyerdynamic DT990 but I'm heading back towards IEMs.  The blue LED power light no longer works but fully functional otherwise.  The sound is quite mature and detailed, has a nice vibe , separation, layering and soundstage are all impressive for its price point.  You can tube roll if you like (included tube is Electro Harmonics) it uses dual Wolfson DACs, the RCA  on the back doubles as an input/output when no USB cable is plugged in so you can use the unit as a DAC or stand alone headphone amp.
Included is the dac/amp, power supply and USB cable.
Specs:
  • Aluminum chassis
  • Dual Wolfson WM8470 DAC chips
  • XMOS USB chip
  • Supports up to 192 kHz/24-bit playback
  • Asynchronous USB 2.0 transmission
  • 12AU7 tube
  • Transistors for class-A buffer
  • Supports ASIO, KS, and WASAPI modes
  • Inputs: USB 2.0, RCA (L, R)
  • Output: ¼ in (6.3 mm) headphone jack, RCA (L, R)
  • Operating voltage: DC 12 V
  • Frequency response: AMP 10 Hz – 100 kHz +/- 0.5 dB; USB 20 Hz – 20 kHz +/- 0.5 dB
  • USB sample rate: 16 – 24 bit; 44.1, 48, 88.2, 96, 176.4, 192 kHz
  • Distortion: 0.03% (1 kHz)
  • Output power: 2100 mW (32-ohm load)
  • Gain: +6 / +17 dB
  • Crosstalk: 110 dB
  • Impedance: 16 – 600 ohm
  • Dimensions: 5.5 x 3.2 x 3.2 in (14 x 8 x 8.2 cm)
  • Weight: 14.5 oz (410 g)
74451032_1388138464693489_4563543609747439616_n.jpg.47431aa65552af1e227f282dab4a66f3.jpg
73497887_392416708307054_7795510163594543104_n.jpg.e1edde8c3cf304a9850f1360ddf964e6.jpg
75369115_2508386202775026_7393255428005560320_n.thumb.jpg.b86b14f62ec985978ff81310f3cf3f29.jpg
Edited by Ewok209
