rheo Posted October 25, 2019 Posted October 25, 2019 hi there I have a 5.1 setup in my lounge room. I have a cable from behind my TV, run to each rear surround left and right speakers. I would like to put my sub-woofer next to the rear left speaker. But I only have a socket with a single red/white terminal. Can I somehow chain the rear left speaker and sub-woofer together? (Trying to avoid getting a sparky in to run the sub-woofer wire to the back of my lounge room. Sub-woofer model is Velodyne Impact 12. AV receiver is an Onkyo TX SR-308 Cheers
Primare Knob Posted October 30, 2019 Posted October 30, 2019 What type of cables are you running, and what type of red white terminal? It is unlikely that you can mix them.Have you thought about using a wireless transmitter and receiver for the sub?
rheo Posted October 30, 2019 Author Posted October 30, 2019 1 hour ago, Primare Knob said: Have you thought about using a wireless transmitter and receiver for the sub? i am considering it. do you have any recommendations?
Primare Knob Posted November 1, 2019 Posted November 1, 2019 i am considering it. do you have any recommendations?I am not familiar with any, but the ones that can set delay/timing might be more useful.
betty boop Posted November 1, 2019 Posted November 1, 2019 On 25/10/2019 at 7:02 PM, rheo said: hi there I have a 5.1 setup in my lounge room. I have a cable from behind my TV, run to each rear surround left and right speakers. I would like to put my sub-woofer next to the rear left speaker. But I only have a socket with a single red/white terminal. Can I somehow chain the rear left speaker and sub-woofer together? (Trying to avoid getting a sparky in to run the sub-woofer wire to the back of my lounge room. Sub-woofer model is Velodyne Impact 12. AV receiver is an Onkyo TX SR-308 Cheers sis make a wireless kit http://www.clefhifi.com.au/catalog/product_info.php?products_id=3903&gclid=Cj0KCQjwjOrtBRCcARIsAEq4rW7ND8EugvaIO2jva0-cuYZk6iA6FNB5huuH-gfBk_lkuFtASRCdEG4aAglMEALw_wcB however if no power back there where sub is going then will need a sparky who likely run a sub woofer cable same time not costing g much more
Guest Posted November 1, 2019 Posted November 1, 2019 1 hour ago, betty boop said: sis make a wireless kit I did wonder who Sis was??
betty boop Posted November 1, 2019 Posted November 1, 2019 8 minutes ago, Snoopy8 said: I did wonder who Sis was?? might have to ask SIRI
Soundfever Posted November 2, 2019 Posted November 2, 2019 Are you saying that you have a RCA red and white socket at the rear of your room near where you want to put the subwoofer?
