metamatics Posted October 10, 2019 Posted October 10, 2019 Any recommendations for a power amp to use with my plinius 8150 used as a pre . looking sub $1000 range will be used with focal 1007 s electra speakers .
A J Posted October 10, 2019 Posted October 10, 2019 Stupid question - but is there an issue with the amp in the Plinius ? They are pretty good?
metamatics Posted October 10, 2019 Author Posted October 10, 2019 ha stupid question? has pre outs for a purpose . Nothing wrong with the amp at all just looking to see a power amp aspect
A J Posted October 10, 2019 Posted October 10, 2019 Were you after more power or a different sound. The 8150 from memory has 150W/8ohm and was well regarded. I once had an 8200P power amp.
Irek Posted October 11, 2019 Posted October 11, 2019 Matching preamp + power amp + speakers is a headache. Maybe you consider adding subwoofer or switching to Electra 1028.
blakey72 Posted October 11, 2019 Posted October 11, 2019 What are you wanting to change? Watts more or less doesn't do much. A different power amp may change things slightly. I sometimes use my Exposure XXVIII with my 9200 as a pre. Slightly changes the sound. Not $1000 worth though.
