Item: OAD 2 x CP1 Preamplifier and 3 x UF1 Power Amplifier
Price: $POA for CP1 & UF1 pair or separate UF1
Item Condition: Perfect and 3yr warranty
Reason for selling: Demo stock and new models arriving.
Payment Method: Pickup - Cash, Direct Deposit
Extra Info:
https://sonicpurity.com.au/brands/oad
OAD Ultrafidelity affordable hi-end amplifiers without compromise in performance and compare favourably with the very best hi-end amplifiers.
Demonstrations available by appointment only.
Only 2 x CP1s and 3 x UF1s are available. Preference will be given to CP1 and UF1 pair purchased together.
However 1 x UF1 is available for separate sale.
Available in Silver and Black.
CP1 Features (RRP$6500):
Remote control
8 x discrete shunt regulated audio power supply
All discrete line stage for optimum signal integrity.
DC coupled (ie. no capacitors in audio path)
Silver plated over OFCopper input and output connectors.
Switched resistor ladder precision volume attenuation located as close as possible to input connectors (range -71.5 to 0dB).
Silver plated relays for input switching.
TFT touch display for complete control of attenuation, input selection, L/R balance control, screen timeout (0-60s) if required , able to learn any remote control codes.
10mm thick aircraft grade Anodized Aluminium front panel
Non-magnet all aluminium chassis.
Dimensions 430(W)x120(H)x360(D)
3 year written manufacturer warranty
UF1 Features (RRP$6300):
200W / 8 OhmsOAD3.thumb.JPG.30ba468ed8a03658b5f0ea3b35368557.JPG
Voltage gain: 26.4dB
Bandwidth: 0-100kHz (-1dB)
Class A/B design (10W Class A) utilizing ThermalTrak transistors for ultra-linear amplification.
Silver plated over OFCopper RCA input and output connectors.
10mm thick aircraft grade Anodized Aluminium front panel.
Dimensions 430(W)x160(H)x360(D)
Photos:
Edited by OAD U/F
