I decided to try the USB input of my headphone amp for the first time but couldn''t get it to work running Foobar.
It does however work with MediaMonkey.
I've tried another USB headamp and the same happens. OK with Media Monkey but no sound with Foobar. I use FLAC files.
Anyone have any ideas as to what obvious thing I'm missing? :confused: and frustrated!
As I remember there is a 'console' in Foobar which will print error messages - try looking in there if you haven't already. I remember that setting the correct number of bits etc. in the output options was required to make it go correctly...
Would you be able to point me in the exact direction to these settings? (just changing the font size in Foobar took me forever!).
Gidday Cliff,
If you're using one of the latest versions of Foo, then it's ;
File > Preferences > Playback > Output.
Choose the correct device from the dropdown list in the right hand pane at the top.
Cheers, Shane.
Thanks Shane :)
So simple, so obvious, yet so far away from my simple mind...
PS And a noticeable improvement over MediaMonkey too!
