Item: Mark Levinson No.531H Power Amplifiers
Price: $12,000 $10,500 $9700
Item Condition: As new (10/10)
Reason for selling: NLR and Need Money
Payment Method: Pickup - Cash, Paypal, COD Only
Extra Info:
Bought in April this year from a European authorised dealer  to power my Usher BE-10 speakers but the ushers are so efficient they don’t benefit from a lot of power these behemoth can put out and I need money for a Japan holiday. Australian retail price for these is over $20,000
Mark Levinson No. 531H Monaural Power Amplifier
The No 531H and No532H are both true mono-block designs with independent power supplies for each channel and are rated at 300W per channel into 8 ohms. The transformers and power supply designs deliver unsurpassed dynamics and transient responses for today’s demanding audio formats and provide stability with even the most difficult to drive loudspeakers. Fully differential circuitry ensures that balanced input signals stay that way throughout the signal path and traditional Mark Levinson “Hurricane” binding posts offer secure termination to the loudspeaker.
The four amplifiers in the No500H Series are the definition of truly outstanding performance in their respective categories. Drawing from the Mark Levinson heritage, while utilizing a new, straightforward, balanced, current-feedback design creates a new series of amplifiers that must be listened to in order to be fully appreciated. The final result is impressive even for the Mark Levinson high standard of excellence.
Main Features
•Reliable, high-power in four different channel configurations provide ideal solutions for any system
•Isolated chassis and signal grounds minimize noise, optimizing detail, even at low listening levels
•Fully-differential circuitry with both balanced XLR and single-ended RCA inputs
•Ethernet and 12V trigger control capability for system integration
Inputs one balanced XLR input per channel; one unbalanced RCA input per channel
Speaker Connections one pair “Hurricane” loudspeaker outputs with banana-plug sockets per channel (banana-plug socket not available on the 230 VAC models)
Communication and Control one Ethernet 10Base-T port; one 3.5mm mono (tip/sleeve) mini plug trigger input, 3-12Vdc; one 3.5mm mono (tip/sleeve) mini plug trigger output, 3-12Vdc; 3-pin IEC standard power connector
Rated Output Power into 8 ohms 300W/ch (20Hz to 20kHz at 85dB, reference level: 2.83 Vrms
Input Sensitivity 2.83Vrms output at 130mVrms input
Gain 26.8dB
Input Impedance 60 kΩ (balanced); 30 kΩ (unbalanced)
Power Requirements 100V~, 120V~, 230V~, factory set for destination country;
Power Consumption 300W
Height (with feet): 7.65" (19.4cm); (without feet): 6.97" (17.7cm)
Width 17.75" (45.1cm)
Depth 19.83" (50.4cm)
Weight Net Weight: 52.5lb (23.8kg); Shipping weight: 62.5lb (28.4kg)
Tags: Krell, Mcintosh, audio research, luxman, accuphase, esoteric
Photos:
ml3.jpg.7871e6d8eee39790410a667d0c837a88.jpgml2.jpg.1d879c364d0b9ce237a8c8144afd41a8.jpgML1.jpg.ce6a6162caf6d5d025c44cf6150a5f51.jpg1086003115_MarkLevinson-1(2).thumb.jpg.5b25eb274554f50037672aa1010b9a05.jpg925874140_MarkLevinson-2(1).thumb.jpg.efc4617e250e944f5389c179d10a9b48.jpg1064134261_MarkLevinson-1(1).jpg.4f49020b404ff710d67a37576b500687.jpg938817766_MarkLevinson-3.jpg.478d0f04072f2db3159109feb5ef9aa7.jpg1352468835_MarkLevinson-4.jpg.ffcfce770282fe5d87900fe6dd99f2cf.jpg110960688_MarkLevinson-2.jpg.bc13d05eceaac69adbc54ce8acf41e5e.jpg793595469_MarkLevinson-5.jpg.7d61300bb2cd288c626a5dd5a56fd411.jpg1852775615_MarkLevinson-1.jpg.241555ee10fd86478aa88c1f4eff7b8b.jpg
Edited by SoundGuy
mistakes
  • Love 1
Great seller and bloke, whom I have bought from. These should not last long at this price.
Edited by AndrewLeePerth
Typo
  • Thanks 1
