Spinnergeoff Posted February 14, 2019 Posted February 14, 2019 (edited) Item: Subsonic Fusion III Speaker System Location: Baulkham Hills - Sydney Price: $1200 ono Item Condition: used but good Reason for selling: my hobby is building and/or rescuing speakers; can't keep them all, but it's looking increasingly as if I'll be remodelling the theatre room to fit these in as they sound better than what I'm using now but are an awkward fit for the room as it stands. (That can be fixed if there are no takers) Payment Method: Pickup - Cash, Paypal, COD Only Extra Info: This is a set from the late 1990s, designed by Ralph Waters who was also the founder and designer of the Richter speakers back in the 1990s. The large front and rear speakers are the same except that the front L+R+Centre each have an inbuilt powered subwoofer, so the bass generated by this setup is amazing. But it's not just about bass - the audio quality is exceptional and can be used for music as well as movies. They originally sold for around $7k, in fact the dealer's receipt I have for this set shows $7999. The drivers used are high class and have rubber surrounds, so last a long time. The inbuilt subwoofer amplifier is rated at 225w, and the low frequency response specified is down to 25Hz. There is actually no specified power rating for the five speakers, but sensible use will not damage most speakers regardless of the maximum power output of the amplifier. Cabinets are heavily built, with the floor standers weighing in at 18Kg each. Apart from some fading of the Jarrah veneers, the speaker cabinets and grilles are good. The amplifier had some mains filter caps and two transistors needing replacement and this has been done - fairly standard maintenenance in a power amp - with thanks to the original amplifier designer who supplied schematics, and a friendly tech who did the component replacements. The sound is sensational. You'd have to pay upwards of $10k now in new gear to get near this audio quality combined with theatrical slam. Original Documentation: comes with various original brochures and instructions - see photo. How they connect up: They connect from the surround amplifier as follows - on the back plate of the Main (R) speaker there are inputs for L+R+C. The inbuilt sub amp and associated circuitry sorts the bass from the midrange and treble, and directs signals to the appropriate drivers. Signals to the Centre and front Left (Slave) are via thick four wire cables (supplied) from the Main which plug in via Neutrik plugs. The rear effects speakers connect directly as per usual from the surround amp/receiver. The surround amp should be set for front & centre speakers Large, and Subwoofer Off. The three subwoofers have their own volume control on the back plate so the amount of bass can be adjusted to suit your taste and the efficiency of the speakers in your room. My tests with action movies have been exciting - I had to back off the bass volume a bit because it was shaking the room. Dimensions: All four floor standers are 1120x210x285 (hwd) while the centre is 235x700x380 (hwd). Delivery & Setup: free and done by me in the Sydney metro area. Otherwise ask - if it's within the realms of possibility I'll travel further and charge for petrol etc. I have no packaging material for these, so shipping by courier would present problems, but could possibly be organised - ask me about this. Let me know about your surround amplifier and room just to confirm suitability and whether any other cables are needed. Pictures: Edited February 23, 2019 by Spinnergeoff 2
