muzzagruzz Posted December 6, 2018 Share Posted December 6, 2018 Item: Cymer Mono Ultra Linear Valve Amp (designed and made by Elson Silva) Location: Sydney Price: $1750 plus delivery/packing by courier if required. Item Condition: Excellent Reason for selling: NLR Payment Method: Pickup - Cash, COD Only Valves: 6072A, 12AT7, EL34 Weight: 10.0 kg Dimensions: 420(w)x390(d)x75(h) Extra Info: Beautifully made and designed by one of Australia's premier valve amplifier designers - Elson Silva. Purchased secondhand from Dr Rod Crawford in April 2018 and only used sparingly by me since. I understand it is approx. 5 years old and Rod told me that he didn’t really use it much in that time, so plenty of life in the valves. Rod requested that a passive volume control be installed, however, as it was designed as a power amplifier I asked Elson to convert it back to that. The below modifications were completed. This is a beautifully designed valve power amplifier with liquid smooth performance. I had it powering my Legend Kurre 9 bookshelf speakers and it played them beautifully. With these speakers connected, the Cymer provides approximately 45 to 47 watts RMS and even with the relative inefficiency of the Kurre’s, at 84 dB, it was more than enough to extract wonderful detail and solid bass performance. I should add that this amplifier outperformed a Luxman L507-uX costing $8k! It did so quite easily too. Works beautifully with an ME preamplifier! The speckles on the perspex is just dust. Modifications: 1. Passive volume control removed; 2. New Perspex front panel installed; 3. New higher quality RCA’s installed; 4. Plates above power transformers resprayed in black; 5. Bias adjusted Thanks for looking. Link to comment Share on other sites More sharing options...
aab Posted December 6, 2018 Share Posted December 6, 2018 It is stereo rather than mono isn't it? Link to comment Share on other sites More sharing options...
muzzagruzz Posted December 6, 2018 Author Share Posted December 6, 2018 3 minutes ago, aab said: It is stereo rather than mono isn't it? Yes, it is a stereo power amplifier. However, if you were to cut the thing in half it would be two mono amps - designed that way. 1 Link to comment Share on other sites More sharing options...
lowpoke Posted December 6, 2018 Share Posted December 6, 2018 13 hours ago, muzzagruzz said: Yes, it is a stereo power amplifier. However, if you were to cut the thing in half it would be two mono amps - designed that way. Your description should then read 'dual mono'. Link to comment Share on other sites More sharing options...
denimhunter Posted December 7, 2018 Share Posted December 7, 2018 @petng Link to comment Share on other sites More sharing options...
muzzagruzz Posted January 5, 2019 Author Share Posted January 5, 2019 To be re-listed. Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2019 Share Posted January 5, 2019 This advertisement has been withdrawn or the offer has expired. Link to comment Share on other sites More sharing options...
