Hi guys, ive got a cheap data projector that i have a problem with.
Ive got my sony bluray player hooked up to my onkyo 605 via component, then component out of the onkyo to the projector.
The only way I can get the onkyo to play dts-hd is by setting the bluray player to 720 or 1080 via component. The only problem is when i so this the projector shows the picture but every now and then the picture cuts out or goes blank then comes back on. Works fine when set to a lower resolution, the projector manual says it can accept 1080.
Anyone know what the problem could be? should i try connect the projector straight to the bluray and bypass the onkyo to see what this does?
thanks.
thanks.
Yes bypass and see what happens.
