SkItZo Posted November 27, 2008 Posted November 27, 2008 (edited) Looking for suggestions on a home theatre system, looking at getting a Onkyo 605 and have $1,500 left to spend on speakers. My room is 4.5w/4L will be running a PS3, 360 and my pc which has a Auzentech X-fi Prelude through the 605. Main usage will be movies and games. Cheers Edited November 27, 2008 by SkItZo
Adelaideltpc Posted November 27, 2008 Posted November 27, 2008 Looking for suggestions on a home theatre system, looking at getting a Onkyo 605 and have $1,500 left to spend on speakers. My room is 4.5w/4L will be running a PS3, 360 and my pc which has a Auzentech X-fi Prelude through the 605. Main usage will be movies and games.Cheers Check out the Jamo 606 5.1 package (RRP ~ $2500, but can be had for well under $1500).
50mxe20 Posted November 27, 2008 Posted November 27, 2008 Focal Sib Cubs can be had for $1500. Or could a month or two back. Perhaps with recent price rises this is no longer true but worth checking out.
Mitcon1503562253 Posted November 27, 2008 Posted November 27, 2008 I also think the Jamo 606 5.1 would be ok, I also think at that price point you could also look at Accusound (Australian Speaker company) they sell 5.1 systems on ebay for around $700-$800 brand new (RRP $2,500) which are ok as well with full warranty. At $1,500 your not going to get the most musical speakers but there are lots of options that are good for movies/gaming. Also you could look at 2nd hand as there is always good value to be had there. With a room that size you wont need monster speakers but do give thought to speaker placement and room acoustics as being pretty much square you will end up with some standing waves issues.
50mxe20 Posted November 27, 2008 Posted November 27, 2008 Yes, if you could add a $1K you could get into some pretty good floor standers. But that is always the case isn't it, the more money you spend the better you get. My daughter has the Sib Cubs and likes them.
SkItZo Posted November 28, 2008 Author Posted November 28, 2008 Wow, those Jamo's look incredible. Is it worth stretching by budget a bit to get the HSC8's over the HSC6's?
POV Posted November 28, 2008 Posted November 28, 2008 here is another option for you. http://www.selbyacoustics.com.au/storefron...amp;i=243608583
Adelaideltpc Posted November 28, 2008 Posted November 28, 2008 (edited) Wow, those Jamo's look incredible. Is it worth stretching by budget a bit to get the HSC8's over the HSC6's? There always are better ones, how far can you stretch? ... :-) BTW, haven't seen/heard of HSC8's Edited November 28, 2008 by Adelaideltpc
SkItZo Posted November 28, 2008 Author Posted November 28, 2008 Ummm, prolly about $100-150 Bit of a typo before, they're Jamo s606 HCS8's basically the exact same but with a SUB300 instead of the SUB250 Ebay linky http://cgi.ebay.com.au/JAMO-S606HCS8-5-1-H...%3A1|240%3A1318
Adelaideltpc Posted November 29, 2008 Posted November 29, 2008 Ummm, prolly about $100-150 Bit of a typo before, they're Jamo s606 HCS8's basically the exact same but with a SUB300 instead of the SUB250Ebay linky http://cgi.ebay.com.au/JAMO-S606HCS8-5-1-H...%3A1|240%3A1318 Go for the bigger sub if you can, but even with sub300 - it could be had for under $1500 (from HN) :-) I think some one said in another thread that he bought the 606 with sub300 for $1300. Worth pm him to find out....
SkItZo Posted November 29, 2008 Author Posted November 29, 2008 Go for the bigger sub if you can, but even with sub300 - it could be had for under $1500 (from HN) :-)I think some one said in another thread that he bought the 606 with sub300 for $1300. Worth pm him to find out.... Any chance you remember who it was or what thread? Thanks
Adelaideltpc Posted November 29, 2008 Posted November 29, 2008 Any chance you remember who it was or what thread?Thanks Here it is: http://www.dtvforum.info/index.php?s=&...t&p=1210081
bowds Posted December 1, 2008 Posted December 1, 2008 Looking for suggestions on a home theatre system, looking at getting a Onkyo 605 Is the 605 still available or are you getting the 606?
SkItZo Posted December 1, 2008 Author Posted December 1, 2008 They're selling on Ebay for $600-$700 but im thinking about holding off for a bit and geting myself a 706
