okay as a spare TV i got a usb tv thing the other day.
got it working in the office on my work notebook, easy as.
all channels piece of cake.
got it home last night to WOW the mrs. and get some brownie points.
but can only get ABC (around 15 diff. ABC Channels)
is this purely a reception issue? work is a concrete block building and i'm bordering on lower ground, home is old stone cottage.
here is a screen shot of the ABC CH's i can see.
http://img.photobucket.com/albums/v53/phla...BCDTVFIGURE.jpg
Can't provide much help if we don't know where you are.
Does your new TV dongle have an external antenna connection?
These units rely on strong signals to operate properly, usually near main cities, so it may be that your stone cottage dosen't have such strong signals....how do you receive normal TV there?
Better off just take home some flowers for the Mrs..well it used to work!
just outside of the CBD in Adelaide.
tele is new chimney mounted number, works faultlessly.
the USB has it's own little antenna.
Yes, it's most likely purely a reception/signal issue.
From work, you may be receiving the UHF translators in Grenfell St.
Typically, the little antennas supplied with DTV 'dongle' tuners are next to useless, unless there are very strong local signals.
Those antennas will work best on UHF frequencies, due to the smaller length of the antenna.
At home, you are probably reliant on receiving the main VHF transmissions from Mt Lofty, which the little antenna will be much less likely to receive... particularly indoors with stone walls.
Try connecting the receiver to your external antenna.. you will need to re-scan the channels.
