Looking to buy myself a decent projector, looking to pay around 1,000 dollars.
I need a few tips too, looking to buy it for games and movies!
Its going to be in my room, about 5 meters away from the wall.
thanks guys.
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
thanks guys.
To be honest there aren't any decent projector for under $1500. You need almost $1500+ to get a decent HT projector. So advise to you is to save more money until you budget can purchase a decent 720p projector and then the model you can consider are Mits 1100, Sanyo Z5 and Sony AW15. Buying right now with a budget around $1000 means you will soon regret making that decision. Another option is to keep your eyes on the forum and fleabay you never know that there might be second bargain pop up but with Aussie Dollar in its current shape bargain will be hard to find.
Edited by jliang70
so your saying something like this?
http://cgi.ebay.com/SEALED-BRAND-NEW-Sony-...id=p3286.c0.m14
You may want to have a look at the BENQ W500 it has good specs vertical and horizontal lens shift and HQV scaler that you would normally find only in $4k+ projectors. It will do a 110" Diagonal screen at 5m as well.
Check local Harvey Norman store as they are doing them for a great price - can vary from store to store so shop around.
http://cgi.ebay.com/NEW-BenQ-W500-LCD-HDTV...id=p3286.c0.m14
This is is 800 bucks buy now, seems preety good.
will ps3, ps2 dvd movies all look preety clear in the BENQ W500?
Also, what sound systems do you guys recomend, and will i need a reciever?
It depends on how much you want to spend?.
  • Volunteer
My room is 3.9 meters (wall to wall)
I'm slightly confused is it 5m or 3.9m?
What screen size are you looking at?
If you go here you can input the pj model you are interested in and see what throw distance you need for the screen size you want.
This and the other ebay link are both in US dollars. They both only state shipping to the US only.
Also USD800 = AUD1200ish with the current dollar falling plus count on at least another $100-150 for shipping from the US....
+ no local warranty + maybe transformer/adaptor etc...
to the OP, i reckon look for a quality second hand unit.. maybe an Epson tw600/700 or Sanyo Z4/Z5 ??
sorry mate, i just got the tape measurer after i said that
its 3.9m meters wall to wall.
im willing to spend just about 600 for a sound system.
and i still need ideas on what projector to buy.
thanks.
i picked up an ex demo panasonic ax200u for 1070 bucks it has about 20 hours on it.. and my projector sits about 3.9m from wall to lens.. has excellent placement ability ness..
Edited by xcracer
ive been looking around on ebay for a bit, and came across theese two :
http://cgi.ebay.com/OPTOMA-HD65-DLP-TV-HD-...id=p3911.c0.m14
and
http://cgi.ebay.com.au/BRAND-NEW-LG-DATA-P...1QQcmdZViewItem
Are any of them worth buying?
I would avoid the cost of second had as you do not know the state of the lamp and also how many "real" hours have been done. If the machines has been turned off and on many times (so many people I know turn it on off 3/4 times a day which is not good for the lamp) then lamp could go and then you are up for $350 - $500 for a lamp depending on the model. Buy local get the warranty and get it new check out some of the deals going down locally before making a decision. I would check out the Mitsubishi HC1100, Benq W500 or the Epson TW700 the HC1100 performs well but slightly lower in spec. I had a friend who picked up the BenQ W500 from a major retailer for about $1350 BRAND NEW.
i,ve seen new mits 1100 for $1250, if you squeeze audio budget at least you will have new 720p respectable projector. pm for more details. cheers.jeff
