Damien Buckley Posted October 7, 2008 Posted October 7, 2008 (edited) I have my DMR-BW500 connected to my Denon AVR-4306 using HDMI. As my receiver doesn't decode HD-audio so up to now I've used the 'Secondary Audio' setting which sends LPCM for all modes. I'm just wondering if I should be using 'user' and turning 'Secondary Audio' on - which I think outputs a Dolby Digital / DTS Bitstream. Any ideas which is best folks? Incase anyone else has similar kit - I've got this pair connected to a Pioneer KRP-600M 60" plasma monitor and switching to Chord Silve Plus1.3 HDMI cables from the Panasonic ones I bought previously, has made a HUGE difference - picture is better, sounds is waayyy better - bass is cleaner and deeper and the overall sound much improved. I bought them from hificables.co.uk as they were about 30% cheaper (delivered in a week) than the best local cash price I could get. just thought I'd throw that in. Edited October 7, 2008 by Damien Buckley
Shonky* Posted October 7, 2008 Posted October 7, 2008 Using the LPCM method from the player is the best option as long as the player is decoding the TrueHD/DTS HD MA tracks and not the regular DTS or DD tracks.
Damien Buckley Posted October 7, 2008 Author Posted October 7, 2008 Using the LPCM method from the player is the best option as long as the player is decoding the TrueHD/DTS HD MA tracks and not the regular DTS or DD tracks. Thanks Mate - yes I can select which track to use on the player.
