Hi all
my 508 xda is hooked up to an external antenna and i'm in line of sight to the transmitter (assuming the transmitter is on Black Mountain in Canberra)
Occasionally, and it seems to be getting more frequent, if I try to change to ABC (2), or 20, or 22, the TV just goes into this ' black hole'. Produces a message like "No Signal Found" and then stays black. The program info box comes up correctly with program info, but shows 0% signal strength.
Then after this it sometimes tunes in perfectly after maybe 1 or 2 minutes! And the signal strength shows 100%.
Other times it tunes in perfectly within the 7 seconds that appears to be normal for this TV!
Pioneer helpline keeps saying it is because I don't have a 'digital' external antenna! But ABC2 and ABC work perfectly all the time on my SD Sony HardDrive recorder...
Anyone else had this problem?
cheers
Satz
