stevodude Posted June 27, 2008 Posted June 27, 2008 Hi guys/gals I have just waked in a new HD stb olin hdtv-2000b, works beautifully apart from some sound issues. Using coax digital out to JVC RX 5030 now when I am on normal SD channels the sound is clear and works perfectly, switch over to 7 and win HD, and the audio gets quieter on the L&R and the center is super muffled, ie I can barely hear any voices at all. switch the amp to 'all channel stereo' and it works fine. Maybe my problem is the AMP can't decode AC3 or something? Any ideas?, cheers, stevo.
bullys09 Posted June 28, 2008 Posted June 28, 2008 hi Stevo I Just purchased one yesterday, and i have the same problem, i think it maybe the signal itself because a mate in Gosnells has a different box and has the same problem. Im in Armadale and i am also having problems with getting channel 7 one minute it is there next its gone.. Garry
