hi all
I have a Sony DVD Recorder connected via HDMI to my Pioneer 508 xda plasma.
The Pioneer max resolution is I think 768
The output resolution on the Sony via HDMI defaults to 1080i.
Has the TV somehow 'told' the DVD player the optimum resolution to use?
Would this be the best setting to leave it at, or should I 'manually' set it to 768, or even 1080p?
many thanks
Satz
Pioneer 508 accepts HD as well as Full HD ie 768, 1080i, 1080p. It "knows" what and how to deal with it.
You just need to see which settings turns out better. I set my DVD HDMI output to 756. Although I cannot see any difference for other settings.
Cabernet
hi all
many thanks
Satz
hi all
many thanks
Satz
Seeing as how all the FTA channels are 1080i feeds (even tho this may be upscaled), I personally have found that leaving all sources on 1080i and letting the display deal with it, works well. I think you will find that the Pio downscales to 720 not 768.
But the bottom line is, try the other settings and see for yourself. If you can't detect a difference, then don't sweat it. :)
