Just bought a Dvx-555u and was playing around with the system settings, but unfortunately stuffed up by changing the A/V video output settings to CVBS I think(or something that doesn't work on my tv) and now it displays nothing on the tv screen.
How can I change the video output settings back to the default. I can't see anything on the screen so can't navigate the menus.
1) Is there a way to reset to factory defaults without doing it thru the menus ? eg. pin-hole button on the device or anything.
2) If someone could list the exact sequence of buttons to press on the remote control to navigate to and perform a reset to factory defaults, would be greatly appreciated. Without seeing the display, not having much success at trying to guess it myself.
Thanks,
Andrew
The sequence to get to the restore defaults entry is:
Menu
OK
Down Arrow (5 times)
OK
OK
